spring rates - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2012, 09:18 AM
all show, all go with a 383
spring rates
Im curious to find out what the spring rates are for a 73' chevy nova. i currently have a set of spring in the front, but the car rides stiff and is bouncy, i was gonna cut half a coil out of them to bring the height of the car down. i know i will still have a stiff ride though. im curious to know what the spring rate difference was between a small block car and a big block car. i might have big block springs but i have a small block under the hood.
thanks for the input.
Old 05-21-2012, 09:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The ride stiffness will increase w/the cut springs. "Bouncy" can be a lack of shock damping.
Stock might be in the area of 250# for a six or SB w/o AC to >300 for AC and/or BB. But that's not really going to help you, you'll need to know what the front end weight is to select a spring, most recyclers will weigh the car for you for a buck or three. Drive it half on then get a weight (front), all the way on to get a total weight then half off to get a rear weight, it'll come in handy for other things like computing the HP from a drag strip run.
Old 05-21-2012, 09:44 AM
would you suggest replacing the springs and going back to a stock spring rather than cutting a coil out of the current spring.
Old 05-21-2012, 09:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The thing is, often stock springs are taller than most guys like the ride height to be- although I can almost guarantee you the ride will be better than what you've described here today. Taking a coil off a stock spring can get the ride height right, but the spring rate will increase as well, so it's a balancing act of sorts unless you weigh the vehicle and pick a spring based on that for the rate and use the OEM free length as a baseline for how long the spring needs to be to give you the ride height you want.
If you contact a company like Landrum, they'll prolly be able to get you closer than just buying a stock-spec spring and using it as-is or cutting it.
Old 05-31-2012, 09:22 AM
Cobalt is right on.... if the car is at the height you want it and it is "bouncy" then you need to put new shocks on the car....
leaf spring rates bighotroddin Suspension - Brakes - Steering 3 06-12-2011 11:49 AM
T-Bucket Suspension Spring Rates lanceks1 Suspension - Brakes - Steering 12 01-12-2008 02:46 PM
Spring rates effienut Hotrodding Basics 2 01-10-2007 09:11 PM
Jaguar Spring Rates Hawk56 Hotrodding Basics 2 01-03-2007 07:00 AM
coil spring rates #'s bullheimer Suspension - Brakes - Steering 2 04-01-2005 10:11 AM
