Spring rates for coil over shocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2006, 02:24 PM
I am putting Nissan 280z rear end in a 51 Prefect, but instead of using the strut I am going to use coil over shocks. When the car is done it should weigh about 2500lbs. The original rear spring was rated at 1200lbs, and the car was 1600lbs. Is there any guidelines for determining what coil spring to use.
Old 08-12-2006, 09:05 PM
I don't know if this street rod information is relative to what you are putting together, but the QA1 site has a chart showing spring rates as a function of spring length and rear axle weight.
http://www.qa1.net/
Go to the Street Rod section, page 14 (it loads a pdf file and takes a few seconds to a minute depending on your internet speed).
John
Old 08-13-2006, 05:27 PM
Thank you john for the info. I should be able to figure it out now, if not I will scream again for help.
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 10:16 AM
what spring and shocks for 69 camaro 1969SS Suspension - Brakes - Steering 1 08-30-2005 05:06 AM
coil spring rates #'s bullheimer Suspension - Brakes - Steering 2 04-01-2005 10:11 AM
rear coil over spring rates stea Suspension - Brakes - Steering 8 03-06-2004 06:01 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
