Spring Shackles at correct angle? Wrong Axle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2009, 10:22 PM
Last journal entry: Rear End Disassembly
I purchased the traditional air setup from cenpen speed shop. You can see the setup at: http://www.cenpen.com/traditionalair.htm
The owner told me that any size axle would work with the setup. So I ordered a Bell axle measuring roughly 34" from spring perch centers. However, at ride height, the shackles are completely vertical, with the shackle mount for the perch on top and the shackle mount for the leaf on bottom. There is nearly 1/16" of clearance from the shackles to the axle. When I lower the car 4", the shackle end that mounts the leaf comes close to contacting the spring perch itself.
Not having any previous rodding experience, I do not know if this is sufficient or even possible for good ride quality. Does it sound like a bad idea to keep this axle, or would it be a better idea to go with a bigger perch to perch distance?
Thanks
Old 06-29-2009, 08:33 AM
Frisco's Avatar
Glad To Be Here
I am not familiar with the front air suspension you have the link to. Perhaps that is the way the suspension appears when dropped to the lowest level (No air in system).
For info concerning the more traditional front end straight axle setup I submit the following info.
The angle of the shackles with full vehicle weight should be about 45 degrees.
To correct your installation, you will need a shorter main leaf or swap the axle out for one where the spring perches are further apart.
Go to this LINK for info on how to measure for the correct spring.
Old 06-29-2009, 09:17 AM
That is exactly what I assumed and have read about. Keep the 45 at ride height. However, why would I be told by the builder of a product that the leafs will fit on a 34" spring center to center axle when it does this at ride height:
Old 06-29-2009, 10:10 AM
My mistake, the perches were installed 180* out. Thanks.
Old 06-29-2009, 03:07 PM
Frisco's Avatar
Glad To Be Here
I see that from the photo you posted. Glad you got it figured out.
MII Spring Installation Whippetguy Suspension - Brakes - Steering 34 04-15-2007 11:18 AM
moving rear coil spring location to change rate cboy Suspension - Brakes - Steering 32 03-01-2007 11:31 AM
Correct me if I'm wrong... (10bolt thread, gear swap cost/carrier compatability) killerformula Transmission - Rearend 1 05-19-2005 06:36 PM
Wrong axle cover - UPDATE! frankenvette Transmission - Rearend 3 08-15-2004 08:39 PM
Wrong axle cover? frankenvette Transmission - Rearend 12 08-09-2004 05:23 AM
