Spring shim question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2008, 05:07 AM
v8hed's Avatar
AK427
I need to order some shims for Comp 981-16 springs. I assume I need to order shims that match the O.D. of the 981-16 springs (ie. 1.250")?
Thanks.
Old 07-28-2008, 05:42 AM
engineczar's Avatar
Correct but you must also measure the OD of the guide on the head as the shims come with different ID's as well.
BSE Racing Engines
Old 07-28-2008, 02:04 PM
v8hed's Avatar
AK427
Originally Posted by F-BIRD'88
Comp #4753
Outside Diameter (in): 1.250 in.
Inside Diameter (in): 0.814 in.
more than enough to do 2 heads
Give that man a cigar! Called Comp Cams tech support earlier (sorry, should've updated thread) and that's exactly what they recommended.
Thanks.
Leaf spring mounting question flynbrian48 Suspension - Brakes - Steering 2 01-22-2008 10:30 AM
Valvespring shim question fastrehotrods Engine 6 01-09-2008 10:27 AM
Secondary spring question HammerGVette Engine 3 12-02-2007 12:06 AM
A- body spring question gilliganspl Suspension - Brakes - Steering 2 03-11-2007 09:44 PM
Leaf Spring Question 39chevy Suspension - Brakes - Steering 2 11-19-2003 05:35 AM
