Any stock hydraulic cam with properly operating lifters and fresh springs should turn that RPM no problem.
It is possible the engine is just running out of cam if your engine goes flat at that RPM. Springs will not help that. Too strong a spring on a hydraulic cam will bottom out the lifters and possibly damage the cam. [ December 03, 2002: Message edited by: Infomaniac ]</p> |
[quote]Originally posted by Camaro76:
<strong>i ask more for preventing valve float, acording to the cam spec sheet that cam with the cam/lifter set valve float happons at 5400</strong><hr></blockquote> That could be due to the shape of the cam lobe. Cam grind. An agressive opening and closing speed will float regardless of spring tension. You can try springs. If it does not work you already have good springs for a new cam. |
Zerp lashing is required on most hydraulic setups due to lifter pump, that will get you to 6200 rpm or so.
Outlawed tunes from outlawed pipes |
when you set up a hydraulic cam valve spring you want not more than about 120 lbs on the seat, any more and you will wipe the lobe very easily, if you "0" lash the lifters and use high rev lifters you can get the 6000 plus rpm, if the cam is ground for that range. watch out for coil bind at full lift and make sure the retainer and locks don't hit the seal and guide.
