Springs for hyd f/t cam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2009, 12:00 PM
staleg's Avatar
Last journal entry: Home made gear stick
This probably show you all my huge lack of knowledge, but here it goes:
On Ebay I saw a couple of vortec cylinder heads that, according to the seller, were equipped with springs for hyd f/t cam.
Are there other springs for a hydraulic flat tapped cam than it is for a roller cam?
What would happen if I put those heads for example on a factory roller block?
Old 02-03-2009, 12:18 PM
You should ask the seller for clarification in this case. Sometimes they change springs on these heads to handle more lift cams over .500/ I believe factory, they were olny rated (the springs) to handle 470ish on the lift, but in this case, I would ask the seller for clarification.
Old 02-03-2009, 12:28 PM
staleg's Avatar
Yes I know. These heads are supposed to be "fresh from the machine shop", so mods like guide bosses machined down etc. are done.
The springs are described to handle 0,620" lift. That's pretty much.
If I had a cam with, say ,530" lift, was is ok to use those springs then? I mean, can springs be too stiff?
Old 02-04-2009, 06:48 PM
Yes.
Check the spring specs from the cam maker as to recommended seat pressure and open pressure and compare to the spring specs on the heads.
Higher pressures, then recommend, can wear the cam faster.
Old 02-05-2009, 07:26 AM
vortec heads on ebay
Hey guys those are my heads and my auction.... What a coincidence!!! a fellow Hotrodder!!
These are the springs that are on these heads please follow go to this link and check it out!!! It does infact say (when you click the apps. tab) that they can be used for hydralic roller cams!!!
http://store.summitracing.com/partde...21+4294863036+
This is the kit they were shipped to me in from summit, along with the cam and lifters.
http://www.jegs.com/i/Lunati/638/60105LK/10002/-1#
see photos
i couldn't find the max lift on summit, but this link to jegs has a better description of the same spring
Old 02-05-2009, 07:29 AM
sorry wasn't done yet
any way here's the spring kit and specs from jegs, I ordered it from summit though cuz it was cheaper but they don't have the max lift listed
Name:	motors and rear end 283.jpg
ID:	36119   Click image for larger version
Name:	motors and rear end 284.jpg
Old 02-05-2009, 07:33 AM
cams
If you look through lunati's MANY DIFFERENT CAMSHAFTS, THIS IS THE RECOMENDED SPRING FOR ALMOST ALL OF THEM BELOW 550 LIFT.
iF YOUR CAM IS ONLY 530 LIFT ROLLER OR NOT YOU WILL BE FINE WITH THESE SPRINGS
Old 02-05-2009, 08:11 AM
SSedan64's Avatar
You have the wrong Jeg's link listed, both are for the cam. Yes those will be fine.
Correct link.>>>>>>
http://www.jegs.com/i/Lunati/638/73943K1/10002/-1#
Old 02-05-2009, 03:41 PM
thanks
thanks ssedan, my bad
V8 Convertible Beetle Leaf Springs??? zbhover Suspension - Brakes - Steering 1 01-26-2009 09:44 PM
good cam? boatanchors Engine 6 11-19-2008 08:31 PM
bbc roller cam springs??? k-star Engine 1 04-24-2004 09:04 AM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 11:29 AM
Oddball Cam source? Biggarmike Engine 3 02-02-2003 10:52 AM
