springs weights - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2007, 03:11 PM
tweaked's Avatar
springs weights
Hello
I just changed governor springs and weights in my 700r4. I went with the lightest combo. Now I do not have overdrive is this related? I'm assuming it just is not reaching high enough rpm in drive for it to kick to overdrive. Does this sound accurate. Thanks for any advice.
The number one place for hotrodding
Ron
Old 09-10-2007, 09:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by tweaked
Hello
Ron
the inner springs have the greatest effect on light throttle shifts.
The weights have more effect on the higher speeds shifts.
I'd change the weights first , a bit heavier
Leaf Springs... 65comet Suspension - Brakes - Steering 2 05-27-2007 01:21 PM
Consequences of wrong springs on my heads? TVR383 Engine 6 11-23-2005 10:25 PM
Diffrent Springs? strikingthematch Engine 3 12-09-2004 09:12 PM
idel speed affect timing?? smlblcks10 Engine 3 04-14-2004 05:15 PM
Valve Springs GearHead69 Engine 5 07-19-2003 11:00 AM
