Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spun bearing?
Thread: Spun bearing?
Old 02-02-2013, 10:16 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
pull it apart,measure everything,check crank for straight if its forged. If a bearing is spun,plan on resizing the rods. Now when you put it back together you will know every single detail.Aim for a perfect blue print.The learning experience,though expensive will be worth it.
remember,perfection is acceptable
