Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Spun bearing?
Thread: Spun bearing?
Old 02-03-2013, 01:56 AM
tresi tresi is offline
If the motor is making metal the thing to do is to tear it down before you run it anymore and find out where it's coming from. A spun bearing will get worse fast. If caught early it might just need a rod resized or the block aligned honed along with a rering kit. Oil pressure will start dropping if a motor has spun a bearing. It may get harder to crank over as well.
There is really no limit how bad it can get if a spun bearing is allow to continue to run. If you're lucky it will just lock up. If you're not so lucky it could tear up a bearing bore passed the point of repairing or even break a rod and the broken piece of rod could punch a hole in the block.
When you tear it down don't forget to take a good look at the cam and lifters. You might be starting to loose a lobe off the cam.
