square bore/stroke and high rod/stroke ratios - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-02-2010, 06:35 PM
The current Fiat 500 "Twin Air" is definitely worth a Google search, as it is one example of an engine that uses electro/hydro intake valve actuation, AND many other european manufacturers are building similar deseigns if we are to believe the hype in the Magazines.
The " almost magic 86x86 mm figure is also deeply rooted here in European cars/engines My own view it that it allows the best arcitechiture/ packaging /Power to weight ratio, in current 4x4 and Front wheel drive cars.
  #17 (permalink)
Old 11-02-2010, 07:33 PM
Last journal entry: Starting the build, 333ci chev, 195 cc jegs heads
p/w ratio of the engine?
  #18 (permalink)
Old 11-02-2010, 07:50 PM
BigRoy1978's Avatar
OH GOD!!! PLEASE NOT AGAIN!!!! *runs for the hills*
  #19 (permalink)
Old 11-02-2010, 07:58 PM
YES the weight of the engine surely has an impact on the overall power to weight ratio of the car.I know you know what im saying, but A 500 LB v8 USA Engine versus a Fiat 2 cylinder that is less than a 1/4 of its weight .
  #20 (permalink)
Old 11-02-2010, 10:13 PM
what in sam's inferno are you talking about?
  #21 (permalink)
Old 11-02-2010, 10:45 PM
I agree i have done a lot of research on engine weight as well.
http://www.35pickup.com/mulligan/weight.txt
http://forums.hybridz.org/index.php/...weights-table/
http://forums.hybridz.org/index.php?showtopic=59086
http://www.locostusa.com/forums/view...590a5&start=15
!READ AT YOU OWN RISK!
These are the majority of the links I found when I was researching that a few weeks ago. My deal is this on that - aside from the placement of the weight of the engine and how much power it can make reliably and efficiently for how much the engine weighs, it really doesn't matter too much terribly much.
This is my reasoning in that statement - if my engine weighs 400 pounds and is an inline 6 then more than likely it has two cyl in front of the front axle so you have 4 behind it. Lets divide that straight 6 into 6 hunks, that is 66.667 pounds for every cyl (basically). no lets lop off 2 of them that 133.33 pounds of weight hanging in front of those front wheels. that is a 267 pound 4cyl the ca18det weighs in at about that weight fully dressed and makes 200hp lets say the 400 pound monster l6 makes only 135hp. (if you can't figure out i am using my z in comparison you're dumb ) now i have a gain of not only the 75 hp of the motor- but for every 10 pounds lost its close to making 1 more hp for the power to weight ratio. so that is like having a car that not only has a better weight distribution BUT it also has 88 more hp (relatively). In this equation it matters.
Here is the other side to that. cost- and goals
the motor trans and ecu cost about 1500 on average plus shipping so lets just say 1800 to be safe.
Now lets pretend you can't fab or are too lazy to (which is likely the latter around here) so you have to fab exhaust motor mounts fuel lines drive shaft misc hoses wiring the the interior gauges etc.
so lets just say we are at about oh 2800 or so just to swap in the ca18det in the z. you gained 75 hp saved weight so add 13 to the seat of you pants. but did this for 2800 bucks. that is a lot of cash for little gain.
Now there are a few reasons I am talking about a swap. There is not one car out there with the motors these have in them (180sx for example) that is a good car out of the box. the 180 is a horrible car- for that motor. the best setup i have seen in any car is the miata - the new z cars- the new vettes, and the caymans. all the rest have a horrible setup. at one point i read somewhere for example the 911 is like running around with a full diaper - and its true. honestly not many of us can afford the cayman (best setup imho) to own or fix by that matter. even to work on that car ourselves in our garages is a pita. so the next best thing is the front midship engine rwd car. the miata, the z, or the vette. notice these 3 cars- not one has the type of motor i am talking about - the vette is the closest to it. NOW to get off my soap box and go back to what I am talking about.
If for example i take that 2800 bucks I could spend on the ca18det swap and put it in swapping in stronger transmission (z32 5spd) and change the ecu out and put a blower on the engine at low boost i should be making more power with less money spent.
what would be best is if a car had a light weight engine that made power from 2000 rpm to 9000 rpm but was varied for mpg and power (much like vtec) was large enough to put down the tq for throttle response but not so large that it would weigh too much for the car. make the car again front midship engine rwd with independent suspension at 4 corners of the car. Also make the engine balanced and smooth. so not that limits us to a l6 or a v12 and l6 does is not very efficient for space. so that leaves the 12. but the 12 is too much weight (generally) So make it of a small displacement say a 3.0lt give it itbs that go to two upper intake plenums each having a blower on them- now had 4 turbos 2 small to spool up the two bigger turbos and a large enough outercooler for each side intake to handle all the heat plum this into each upper intake the itbs. Now i am starting complicate things. I think you get my point and this post is already too long winded- and "soapboxy" just too many thoughts going on in my head for the past couple weeks spewing out at once from all the research I have done.
  #22 (permalink)
Old 11-03-2010, 05:35 AM
HEY Blight ALL THIS INFO is interesting its what these Forums are all about in my opinion .And im also wondering why I should "run for the hill s" as well.
I am like many other Hotrodders and have a few projects ongoing at any time(a few too many at times)AND personally have a mix of American engined AND other European+Japanese engined projects at the moment.So all of this thread is relevant to me.
Another thread/topic would be about how many forums people are on , but thats another subject for another day.
  #23 (permalink)
Old 11-03-2010, 08:17 AM
I am on a LOT of other forums. There is a myriad of info on forums - its diging through the bs that gets tiring
  #24 (permalink)
Old 11-03-2010, 12:44 PM
BigRoy1978's Avatar
This topic has been BEAT TO DEATH!!!
And some people wont listen to advice on here...and just keep rambling and rambling and rambling about this topic....it gets old! Just like the 7 million (sarcasm) posts about a "350 chevy build-up" or "will this stock 350 combo work?"
just gets old........
  #25 (permalink)
Old 11-03-2010, 01:05 PM
stroke to rod ratio uugh, you dont have to read it .just pass along.The post you made a similar commemt about was first started in 2004,and I cannot find much on the search. So can we continue?????
  #26 (permalink)
Old 11-03-2010, 01:17 PM
you won't find many good in depth answers to those questions on this forum, they simply don't discuss things in that detail as the average hotrodder doesn't need to be concerned with it. I suggest getting started with a google search.
  #27 (permalink)
Old 11-03-2010, 02:57 PM
Thanks for the input,Its worth pointing out that things that are second nature to many posters here ,are very interesting to the likes of me who lives in a different culture , mechanically speaking,Ok so there a few dozen American cars in my neck of the woods, thats it, so I soak up a lot of information on many facets of hot rodding on here and other similar forums.This thread is not very specific, And Big Roy who I note is 21 .is a bit negative and has a totally different view , its a free country.!!!But its facinating to me.Once again many thanks, and i have A Google list beside my PC. a mile long
  #28 (permalink)
Old 11-03-2010, 03:21 PM
I wish you the best of luck in your search. I also suggest that you get a few good textbooks on engine design if you're really interested. They're kinda pricey but contain some GREAT material. Your library may be able to help you there too.
When it comes to this stuff thick text books are better than the internet IMO.
  #29 (permalink)
Old 11-03-2010, 08:57 PM
agreed sirs
  #30 (permalink)
Old 01-19-2012, 12:46 PM
Nothing new in stroke/rod controversy
MY Dad built stock car engines ,back in the '40s. He always looked for Merc blocks. HE said, the closer you could get the engine to "Square" [equal bore & stroke], the more power it would make.
I always argued [as I do here], it is a question of which rpm range you are operating in. "Granny Goodwitch" on her way to church needs a completely different power curve than a teenager, in the middle of the desert , one night, showing his girlfriend he can bury the speedometer.
I think the Car manufacturers have wrestled with this problem for many years. Performance? or Low speed efficientcy. That's a headache,...NOW THROW IN COSTS!!! I am comvinced, that is why we have a 305 chevy [one crank for 305 & 350 {3.48 stroke}]. 305 is a pig after 3000rpm, ... and dead at 6. While 283cu.in. Chevy is good everywhere. WE have old dyno charts around here somewhere.
I regularly ran across 283's [back in the day] with 150,000 miles and more on them. Now imagine what that little motor could do with synthetic oil, fuel injection, electronic ignition, a roller cam [300,000 anyone?].
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 08:48 PM
High Powered Coil's Question Francis Electrical 3 04-12-2004 04:36 AM
Emissions HELP cutsupreme Engine 33 12-27-2003 09:22 AM
