Square bore VS. Spread bore - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2006, 12:38 PM
Hi Guys,
Can someone please tell me what the difference is between a spread bore and a square bore? I called summit about a manifold and they asked and I felt stupid not being able to answer the question.
Thank You
Jim
Old 11-15-2006, 01:04 PM
novajohnb's Avatar
It'll go, or it'll blow...
Square bore- The 4 barrel carb's front and rear throttle plates are the same size.
Spread bore- The carb's rear throttle plates are larger diameter (like a GM Quadrajet or Chrysler Thermoquad)
Old 11-15-2006, 06:56 PM
firestone's Avatar
http://teamrfc.gospelcom.net
Here you can see on a spread bore, the secondarys are bigger
http://www.thecarburetorshop.com/Cart9800.jpg
Here, on a square bore, as was said, they are all the same size. It is a little harder to see though
http://site.mawebcenters.com/ksautop..._thumbnail.gif
These show the difference as you would see it from the underside of the carb
http://marineengineparts.com/shopsit...ia/EDL2696.jpg
Adam
Old 11-16-2006, 03:39 PM
In this photo, there is a Holley 390 square flange on the left, and a 450 Holley spread bore on the right. A Spread bore has the bores spaced farther apart as compared to a square flange. On a Q-jet, or Thermoquad, the rear bores are bigger, but they don't have to be to make the carb a spread bore. Dan
http://hotrodders.com/gallery/showphoto.php/photo/12552
Old 08-06-2010, 06:36 PM
spread bore
Originally Posted by JimKramer
Hi Guys,
Thank You
Jim
when a rocket builder designed a cone for more thrust a speed shop engine builder got the idea to use the concept in a carburetor for better performance.
Old 08-06-2010, 07:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
First- You dredged up a nearly 4-year-old thread and added NOTHING of substance to it.
Second- A rocket uses a NOZZLE for thrust- NOT a cone.
Third- WHAT??
Old 08-06-2010, 08:57 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
Third- WHAT??
Thanks cobalt, Classic rookie mistake. He might unregister after that one.
Spread bore with square bore carb western star Engine 5 10-28-2004 01:16 PM
Ford Spread Bore SDSJap Engine 6 08-16-2004 09:42 AM
holley spread bore power Engine 16 08-10-2004 06:09 PM
spread bore vs. square bore mike5767 Engine 2 06-20-2003 09:46 PM
Holley 650 Spread Bore Kaylah Engine 4 03-03-2003 05:50 AM
