Squeaking brake drum help needed!
I have a 70' chev 1/2 T with front drums. I get a slight squeak on the left front wheel while driving, which increases as the weight shifts as I turn left. When I initially heard it, I pulled the drum and found the shoes cracked with rivets into the drum. The right drum was fine (the original) and still had some meat on it. I replaced the drum, shoes, and springs, pulled apart and cleaned out the wheel cylinder (which looked fine, and was fairly new) as I thought it might have not been retracting back all the way, replaced the wheel bearing. Well, I still get that squeak, and when I brake hard, she'll pull to the left. I can't figure it out. The only thing I can guess is that something is tweaked causing the whole assembly to run eccentric to the drum... I have adjusted the brakes several times. I am afraid that it will start heat cracking again, or I will have to hard brake in the rain and jump in to somebody's lane, and God knows there are just not that many SWB chev's left with no accident history....
My first post and a handful. Any ideas would be greatly appreciated, as this has me stumped, and I am not yet ready to convert to discs....... Thanks. |
1st of
WELCOME TO HOTRODDERS.COM For me I always to brakes in pairs left & right sides equally. those old drums are pretty simple if you have a braking "pull" than its either one side is grabbing or one side is not grabbing Testing the return springs : the simplest test is to drop each one on concrete if it just hits and dosen't make any noise its good,If it hits and makes a twang its fatigued and needs to be replaces Then if you still have the pull you need to check for fluid flow its damn near imposable to actuality check the flex line but it you open the bleeder and nothing comes out its shot what happens is after 36 years of having brake fluid in the hose it will swell and sometimes it will swell closed {swell on the inside and not be visible} so that when you step on the peddle it will push the fluid through and NOT let it return So I would replace the flex hoses & maybe the springs GOOD LUCK & let us know how you make out SR66
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Thanks for the insight. I will dive into it again and check the hose. The springs are new, so that should eliminate those. Have you seen an instance where the hose swell would cause shoes to hang up and drag? Every revolution of the drum I get a short squeak, which is why I think something is causing the shoes to not quite return. Both times I have been into it I insured there was no grease on the shoes. I light sanded both the shoes and the drum along with the old brakleen ******...
YES I HAVE !!
I had 2 70 Suburbans 6 luggers and a 65 Suburban 6 lugger all 4 wheel brakes and after so Long they will squeeze shut . The pressure of stepping on the peddle force the fluid though . But not let it return I dont know ow much they cost nowadays but i think maybe $20. each if IF you get the steel lines to cooperate get some PB Blaster on those steel lines now... just in case soak them a few days before you go to do the job and if the line wrenched dont work use a GOOD pair of vise grips maybe even a little heat from a heat gun or small torch to get the different metals to separate let me know if I can be of further help OK? SR66
Thanks Rob, I'll pull the hose and let you know how it goes.
| drum to disc conversion kits | dmented | Suspension - Brakes - Steering | 4 | 06-06-2007 09:06 PM |
| drum brake spindles modified for discs? | Sleeve396 | Suspension - Brakes - Steering | 13 | 01-19-2005 11:07 PM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| Stuck brake drum on '53 Packard | Malibucdl | Suspension - Brakes - Steering | 7 | 09-16-2003 08:51 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
