Squeaking rubber shakle bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2003, 09:02 PM
New Member
My 48 Ford Tudor Streetrod has a Ford 9 inch rear end mounted on parallel leaf springs.The rubber bushing in the shakles really make a lot of noise, I had the same problem last summer so replaced the bushing with new rubber bushings. Made sure everthing was clean. They started making the same noise this weend again. What can I do to prevent the rubber bushing from making so much noise?
Old 08-25-2003, 09:36 AM
jalopy45's Avatar
Cool
Change the rubber to teflon bushings, which if you can't find the exact ones can be turned down in a lathe from a larger size or load the heck out of shackle pins with graphite. If they are making a lot of noise you may have a slight hanger alignment problem that's causing the bolts to bind.
Old 08-25-2003, 09:37 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
take them apart again & use some anti-seaze or grease on them, thats what I had to do on a couple of cars I owned.........joe
Old 08-25-2003, 09:44 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
get some of that super sticky urethane bushing grease, and grease em up......
you have any grease whores close to you???? they love this kind of stuff ya know.....
Old 08-25-2003, 10:40 AM
Dragon J's Avatar
Last journal entry: Harley/Fire
agree w/above- especially the alignment check- if greased when installed they should not start squeaking unless humidity/wet weather causes the bolts not aligned to bind.
