Squeaking Valvetrain on SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2005, 04:16 PM
Jeeps Are Us!
Last journal entry: The Paint Shop
Hello!
I've got this real wierd problem. My brand new SBC engine which I'm now running for only 100 miles, started to make a sqeak noise from the valves.
At first I thought it's the belts, but it comes out of valves!!!
I have brand new Edelbrock Performer RPM heads ( fully assembeled with springs, valves and retainers) on.
I don't know the reason for this??? Because I haven't done anything special to the engine prior to this sound!!!
After I started the engine for the first time two-three weeks ago, everything was great so I decided to readjust the rockers, put the thermostat in, change the converter to a higher stall and change the oil/oil filter ( about 100 miles on the engine) a couple of days ago.
So I did all of the above and after driving the car for a couple of miles this squeak noise comes in
Does it have anything to do with Octane Boosters? How about using regular fuel?
I only use 95 octane unleaded, but the night before this noise comes up, I had to fill in 87 octane + Ocatne Booster, because there weren't any Hi Octane fuel available at my local gasstation.
Could this have anything to do with it?
When I start the engine for the first time in the morning, it doesn't make this noise until about 5 minutes, then it starts to squeak.
Anyway I changed the gas again right now to 95 octane, drove it for about 10 minutes, and nothing happened.
What is it? Anyone faced this problem before? With Edelbrock heads?
Thanks to all,
Houman SS '70
Old 08-12-2005, 05:11 PM
Bumpstick's Avatar
Hammer and a torch
Just curious but are you running full roller rockers...? Possibly one of the bearings is not oiling or if reg stamped rockers possibly and scored ball...?
Also just really noticed but your from Iran...? Wow...! Pretty cool you have some nice looking American iron over there... Do you drag race or...? Saw the tires on what looks like a dirt track in the distance...?
Old 08-12-2005, 06:21 PM
steve t's Avatar
ex biker, now hotrodder
do you have good oil pressure, at idle
Old 08-12-2005, 11:24 PM
Jeeps Are Us!
Actually, I'm running regualar 1.5 GM rockers.
The problem is that it all happened at once! It was fine for the last two weeks!
And the noise comes out of both heads!
Yep, we've got lots of nice american here, not many of the left though!
The tires are a oval track.
And ther silver Camaro SS is mine!
Take care,
Houman SS '70
Old 08-12-2005, 11:26 PM
Jeeps Are Us!
Yes, Steve. Oil is pumping out of rockers at idle fine.
Could it be the guide seals? ( Valve stem seals)?
Thanks,
Houman SS '70
Old 08-13-2005, 08:43 AM
King of my Man-cave.
What kind of valve covers are you running? If they are stock or stock-type copies, they will interfere with the rocker arms (making them squeak) if they are installed upside-down. This happens more than you might think.
tom
Old 08-14-2005, 12:04 AM
Jeeps Are Us!
Tom,
I'm using extra tall Aluminum valve covers.
Thanks,
Houman
Old 08-14-2005, 04:46 AM
GoneNova/406's Avatar
does it make the squeal going down the road or only at idle.
Old 08-14-2005, 02:26 PM
Jeeps Are Us!
Well, it makes the squeak noise at idle and on the road!!!
When the RPM goes higher the frequency of the noise also becomes higher ( not the volume, just it becomes faster) that's all!!!
I really feel dumb and stupid!
Thanks Gone Nova/406.
Regards,
Houman SS '70
Old 08-14-2005, 10:24 PM
Jeeps Are Us!
Does anyone have any ideas about this one???
Thanks to all.
Old 08-14-2005, 10:51 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
You are going to need to pull the rockers and check for scoring around the ball and rocker tip.
Old 08-15-2005, 10:10 AM
thats a new one on me.when i first started the new 406 it started making a shriek but it sounded more like distributor or the flex plate area.it only did it at idle and for a short time.i thought maybe the oil pump gears galling the pump cover because of tight clearance but it stopped suddenly so maybe it was.does that sound like yours?
Old 08-15-2005, 10:47 AM
engineczar's Avatar
Are you sure the noise is coming from the rockers? Engine noises can be tough to pinpoint. Have you tried running the engine with the fan belts off (just a few minutes)to eliminate the water pump, alternater, power steering etc.?
BSE Racing Engines
Old 08-15-2005, 05:14 PM
Jeeps Are Us!
Yes Engineczar, I did that, that's acutally the first thing I did.
But GOOD NEWS. I found it.
It is as NXS, Hippie, and a couple of other friends mentioned the balls & Rockers.
I think that I'll get a set of new roller tip rockers with balls and nuts from SUMMIT. Do you guys sugges that?
It's acutally 1.6 ratio. I don't know how I can calculate Piston to Valve clearance???
Can someone help me here?
Thanks for all of your hints. I was really getting disappointed of my Car last week, but now I'm back on my feet again.
Take care,
Houman
Old 08-15-2005, 05:25 PM
steve t's Avatar
were the squeez from the 1.6 rockers? your pushrods may have rub the pushrod holes in your heads buy useing 1.6
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
$4,557.99 for SBC 400 Parts/Machine Work DTL504 Engine 35 04-03-2006 05:36 PM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
BEWARE of hidden cost with SBC Yahoo TooMany2count Hotrodders' Lounge 4 01-05-2004 07:32 PM
