Squeaky brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2012, 07:11 PM
mitmaks's Avatar
Last journal entry: Grille
Squeaky brakes
I've installed a set of pads on 2001 Camry a few months ago. I've lubricated parts as needed, bedded in pads. These are ceramic brake pads and they squeak once in a while. I had owner come back and I've regreased them and it still squeaks once in a while. Anything I can do?
There is treatment that you can spray right onto pad/rotor and its supposed to stop squeaks. I might give it a try.
Old 10-23-2012, 08:24 AM
302 Z28's Avatar
Main thing with brake pads IMO is to install quality brand name pads. I will not use any house brand pads insisting only on Wagner, Bendix or Raybestos.
Vince
Old 10-23-2012, 05:14 PM
mitmaks's Avatar
They were "brake best select" not the cheapest ones I could find.
I'm almost thinking I should take them off and take them back and exchange for something better.
http://www.oreillyauto.com/site/c/de...0068&ppt=C0009
Old 10-23-2012, 05:18 PM
Did you put antisqueal on the back of the pads when you installed them? Were the rotors turned on this brake job?
Old 10-23-2012, 05:27 PM
Last journal entry: was hoping for better than this
you didn't say if you installed new rotors or not..
I'd pull um and exchange them for another same set..
I hate ceramic pads.. no matter whom made them.. yes they last longer but they take the rotors out with them..
most times the noise isn't the pads persay, it's the soft china rotors iron..
mitmaks's Avatar
No rotors weren't turned, They were in good shape, I don't like turning rotors unless they're warped, have deep gouges, etc. They appear to be original rotors but they're not cheap china made.
I did put anti squeal everywhere in this picture and even piston itself where it contacts pad.
Old 10-23-2012, 05:37 PM
well.. I'd get warranty pads and scuff the rotors.. the rotors looking good, is bad.. they are most likely glazed.. with no crosshatch..
to smooth is as bad as grooved
Old 10-23-2012, 05:41 PM
mitmaks's Avatar
I've actually been always told that ceramic pads are gentle pads
Old 10-23-2012, 06:11 PM
302 Z28's Avatar
That has not been my experience at all. FWIW BrakeBest pads are not what I would consider quality pads.
Vince
Old 10-23-2012, 06:44 PM
mitmaks's Avatar
They're ok pads, not comparing them to Hawk or EBC etc. They're adequate for daily driver.
Old 10-24-2012, 07:19 AM
302 Z28's Avatar
Except they squeel
Vince
Squeaky engine chevycarlo91 Engine 4 08-11-2009 05:45 PM
squeaky shoe leldai73 Off-Topic 6 08-09-2007 09:58 AM
squeaky alt belt elcaminodragster Engine 2 03-22-2007 09:24 AM
'65 Mustang - Squeaky Stops 65Stanger Suspension - Brakes - Steering 2 01-29-2006 01:35 PM
never-ending squeaky brakes madhat Suspension - Brakes - Steering 7 09-24-2004 06:56 PM
