squeal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2006, 03:40 PM
squeal
when i turn my steering wheel the belt squeals and the wheel bounces what shuld i look for or what shuld i do? its an 86 camaro with a 350
Old 01-22-2006, 01:27 AM
Check the power steering fluid.
Old 01-22-2006, 09:23 PM
milner's Avatar
sounds to me like the belt is to loose, a slipping belt will make it jump. also if it has air in the system it will do the same thing.
Old 01-22-2006, 09:27 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Check your fluid level, be sure that you are using the proper fluid, and check the belt tension.
Old 01-23-2006, 11:19 AM
i checked it and the tensioner was bottomed out so i replaced the belt becuase it was stretched out from wear. thanks
Serpentine Squeal MI2600 Engine 14 01-09-2006 05:43 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
power steering squeal mark b Suspension - Brakes - Steering 1 10-01-2003 07:49 PM
