squish/quench question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2012, 10:54 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
It seems that our Detroit iron (and aluminum) heads are a natural for squish since they have a quench area built it.
But what about 4 valve cylinder heads (Yamaha even has a 5 valve head for their 450cc dirtbike). How can you achieve squish since there is no room for a quench area? Perhaps the engine design such that the charge is already sufficiently atomized and mixed, and they have different/more efficient combustion chambers that mitigate the need for squish?
Old 04-12-2012, 10:41 AM
Many of these multi valve engines are small displacement motorcycle engines that turn extremely high RPMs mounted ahead of a manual gear box on a light weight vehicle that is geared very steep between the primary and secondary reduction systems. So their envionment is much different from a large bore , slow turning (comparativly), mounted in a heavy vehicle with fairly high gearing. So the issues that result in detonation are much different between these vehicle's engine design needs. But if you look closely, you'll usually find a flat band that goes all the way around the outer edge of the typically domed piston that is used with pent 4 valve or 2 valve hemi or the how many valves can you get in there Yamaha. This is called a squish band, it performs the same function as the big pad in a Chevy, Ford, Chrysler motor. The two valve head also comes in a bathtub chamber where the valves may be inclined as done on a hemi but are sunk into a tub that is surrounded by wide squish/quench pads, Yamaha V-Star and the Harley engines come to mind as having this, the former actuated by an overhead cam and the latter by pushrods.
Bogie
Old 04-12-2012, 11:22 AM
Bogie,
I have not thought about the relationship to vehicle weight & gearing as it relates to quench. So apparently motorcycles have it easy based on what you are saying. But many of the newer autos with them fancy overhead cams have 4v per cyl. Granted they tend to be lighter vehicles and run at higher RPM's than old Detroit iron, but they are a far cry away from inherent advantages of motorcycles. The intent of my post was not to single out motorcycles either, I was mainly focused on autos, but I do thank you for pointing out that comparing engines to engines is not apples to apples in this case.
So if I understand, you are saying there outer rim of the piston is the squish band (can't be too much surface area here to be effective?), and the domed piston plays a part of the squish operation in the hemi type head? I would think that to get any type of decent squish with the domed piston/hemi head you would have to get so close that the piston and valves would occupy the same space-time...unless these newer 4v engines have significantly less valve overlap?
~Dan
Old 04-12-2012, 11:28 AM
Also ever hear of the Honda CVCC head?
http://www.forums.murc.ws/showthread.php?t=65948
Old 04-13-2012, 07:11 PM
Bogie,
~Dan
Often the squish band isn't as effective, detonation with pent and hemi chambers is a problem, they like to call it combustion rumble. Its admittedly a little different but left unabated the results look a lot the same. A factor the pent and hemi have going for them is the spark plug is usually much closer to the center of the chamber so the flame front radiates out from there getting to the wall side much faster than a wedge with the plug off to one side causing the burn to have to spend time to get across the bore so the far side (sounds like a cartoon) sees a lot of heat and pressure before the fire gets there so sometimes it goes off by itself ahead of time. The rather subtle changes of the Vortec type chamber compared to those small or large that came before is astounding in effect. It moves the plug in as far as practical so the burn isn't so far, controls the incoming mixture flow with a relief between the the valve and plug and puts the old plug side squish/quench step back in if only by the exhaust valve short turn side.
One also cannot rule out the effect of fuel injection where the unequal mixture ratio and volume distribution of the carb and manifold is eliminated. Additionally with FI, the puddling of fuel immediately behind, if not on the valve backside, puts the heat absorption of vaporization into the combustion chamber instead of within the venturi. Plus, the incoming air (mixture) doesn't need to be heated to force vaporization of the fuel, so the injected engine sees a much cooler mixture at the valve. This forces a better combustion chamber design but that also works better where a carburetor is involved.
Yes detonation sensitivity is related to the load on the end of the crankshaft. The more advantage the engine has in lever arm against those loads the less it tends to detonate. That backs up into the root causes in the cylinder of too much heat over too much time. In and of themselves gearing isn't a cause or solution it just introduces less cylinder heat by lowering how hard the engine has to work.
Bogie
quench/squish 6sally6 Engine 6 12-07-2012 08:07 PM
Question on Squish for a 406 79phoenix Engine 10 11-15-2010 10:27 PM
squish or quench on a supercharged engine smokin63 Engine 7 03-31-2008 05:41 PM
Quench question Horse_pucky Engine 10 12-10-2004 12:22 PM
yet another quench question minesblown Engine 10 10-23-2003 09:42 AM
