ss suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2008, 09:41 PM
daves85ss's Avatar
ss suspension
i just put new shcoks and im still no happy att all with the differnce so im guess i have really bad bushings or what else could it be im hoping only bushings 85 monte ss ty
Old 04-17-2008, 09:50 PM
wretched ratchet's Avatar
one full turn after it squeeks
could you provide more info, like what are you not happy with? could be your rubber and rims
Old 04-17-2008, 10:18 PM
daves85ss's Avatar
well
its like a hollow bammm when i hit a mild bump mainly in the rear but the fron also i know axles are good
Old 04-17-2008, 10:22 PM
daves85ss's Avatar
oo yea
i have mild cam 270 duration 454 lift and forged pistons i think i have stock heads i want 2.02 edelbrock barb 650cfm 400 trans headers im gonna get vacuum advance soon and 194 heads off this info how much horse u think im pullin i got it goin bout 140mph
Old 04-18-2008, 07:52 AM
"BAMMM" usually means two or more objects are coming together when they shouldn't (that is unless your name is Emeril - bad joke, I know)
You mentioned putting new shocks on - - did you stay with the OEM shock? If not then your new shocks could be bottoming out??
You might want to check your spring hangers and everything that they are connected with or to.
Can you get the "bammm" by just hand bouncing the car standing still???
Old 04-18-2008, 10:11 AM
daves85ss's Avatar
yea
it really sounds like my bushings arebad how easy is that to swap
Old 04-18-2008, 10:48 AM
shouldn't be too bad but I'm not that familiar with the 85 monte - - - I'm thinking you should be able to find out where the slack is by feeling with your hands while someone bounces the car, but maybe I'm wrong.
Old 04-18-2008, 03:33 PM
leldai73's Avatar
Its just metal,you're the boss
hate to be the bearer of bad news but the bushings are more difficult to change than one would expect. BUT not out of the realm of possibility.
you going to need a hydraulic press, maybe a torch and a lot of patience. its also important to not crush the A arms or trailing arms. I have a 1984 Monte Carlo SS and so far I've replaced all of the busing with polyurethane, all the ball joints, the rag joint in the steering column, springs, and shocks. I also boxed my lower control arms and tightened the steering box. it handles better now but its a big car.
http://www.montecarloss.com/technical.html check out this site for specific information.
Narrowing a '73 GM B-body Front and Rear Suspension hduff Suspension - Brakes - Steering 2 09-09-2007 08:56 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
how to hang a C- 4 suspension ? Redmist Suspension - Brakes - Steering 1 12-31-2004 11:48 AM
SS El Camino suspension upgrade stinky jinx Suspension - Brakes - Steering 2 06-02-2004 01:53 PM
ss flames camino_man Body - Exterior 2 02-29-2004 04:52 PM
