ss urethane or bc/cc - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2007, 02:49 PM
Hello.
I have decided to graduate from spraying acrylic enemal and move on. With this car i am going to paint light yellow (no metal flake). I am not sure whether to use single stage urethane or base coat clear coat. Will the bc/cc give a much greater shine? Also, with the primer is 4oo wet sanding enough or should i go to 600? I look forward to your thoughts.
Old 03-28-2007, 09:22 PM
400 wet will be fine for the color you're shooting, if it were a metalic color you'd definatly want to go with 600. Clearcoat IMO gives a little better shine but a singlestage also works well in solid colors-the choice is yours. If you've shot acrylic enamel you'll do fine with either system. The single stage will save you a few $$ compared to BC/CC and you can also clearcoat singlestage if desired, making a very durable finish.
Old 03-29-2007, 09:48 AM
Countilaw's Avatar
Cox Custom Cars
I agree with Baddbob. What color primer are you using. A white sealer would be best. It will make your yellow seem brighter.
If you plan on spraying clear over the SS, it would be best just go use a Base coat and then clear coat. It's easier sanding out any problems with the clear coat, than it is with single stage.
Old 03-29-2007, 10:18 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
White base
When shooting a yellow or orange..definitely positively shoot those over a white base as those colors do not hide like some of the others..
I would go BC/CC on that..better color choices are available in BC/CC than in single stage..
Sam
Old 03-30-2007, 02:16 PM
I am spraying a nason (421-17) primer that is kind of a light tan in color. I appreciate the tip on the white sealer. Does anyone have favorites on brands of bc/cc? I thought about shooting Imron ss, but that with the activator was about $300 per gallon. I think you can get a nice bc/cc for that. Thanks again for the help.
Bill
Old 03-30-2007, 02:39 PM
Countilaw's Avatar
Cox Custom Cars
I've used Nason and have very good results with it as a bc. But when it comes to the clear-- you can ask 12 painters which they prefer, and you'll get 12 different answers.
There are a lot of clears available both at your supplier and the net.
When it comes to clear, you have to pick one and practice with it. I have used Transtar, 4Extreme, SPI, Nason, Dupont. They have all worked well for me.
Enamel vs Urethane vs Polyurethane???? MARTINSR Body - Exterior 11 07-02-2011 06:58 PM
I tried urethane and need some advice.... F&J Body - Exterior 3 03-12-2007 01:37 PM
Best place to buy Urethane BC/CC dnwong Body - Exterior 1 11-16-2006 05:46 AM
SS Urethane jcclark Body - Exterior 5 05-19-2006 05:02 AM
BC/CC vs SS opinions on brands? jethro Body - Exterior 5 08-19-2002 01:36 PM
