I have heard of this happening with Edelbrock carbs i have always heard of it as a "dead spot" in the pedal. Try a bigger carb or a different brand maybe.
Well it's none of that. The idle adjustment may be set too low and the choke set too high. The choke may be holding the throttle blades open, but when you jab the pedal it clicks it off (of the high idle ratchet tab) and sets down on the idle adjustment screw (that is not turned in far enough) and kills the engine.
Or it could be the distributer weights sticking and bringing up the idle RPM, and when you jab the pedal they unstick and retard the engine, killing it. |
I had the same problem sort of , 1 check your accelarator pump make sure its pumping. 2 what hole is pump linkage in? 3 move pump linkage oppisite end of holes try it now. 4 jet it up a few sizes. read this some of it may help.http://www.hotrodders.com/t37825-15-1.html
Ed
carb
It might be where you have the vacuum advance hooked up. try moving it to the other port and see if the problem goes away.
keith |
