Stainless brake lines, sealing flare fittings problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2008, 03:13 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
I have ordered stainless brake lines and fuel lines for the 'staing I am working on. I have heard of problems getting these to seal at times.
Anyone worked on these before? Do you have any tips for getting the stainless fittings to seal better?
Old 01-30-2008, 03:37 PM
Wiki Edits: 49
Just remember that stainless brake lines need to be flared at 37 degrees (which requires a special flaring tool) and not 45. Also its a single flare not a double as you would with steel lines. The metal is too hard to take a double flare and will most likely split if you try it. The same with trying to flare it at 45 degrees. If you flare at 37 degrees you should have no problems.
Old 01-30-2008, 03:51 PM
Last journal entry: Albany Oregon Show
Stanless Brake lines
Nice catch Centerline I forgot about this issue and have been dinking with this problem for a day or two now. I hate it when I forget more than I know.
Bob
Old 01-30-2008, 04:20 PM
DARK SIDE's Avatar
flair
Im really glad that there are so many people out there willing to help. I too just got my shipment of stainless lines and I had no idea you had to flair em at a different degree..thax guys..good info.
Old 01-30-2008, 04:47 PM
I have one of these
About one hundred dollars but works GREAT.
With the AN fittings ... the stainless lines can be made to look real nice.
Old 01-30-2008, 05:33 PM
DARK SIDE's Avatar
stainless
All the fittings are set up for 45. How does it handle the 37 or are there different fitings?
Old 01-30-2008, 05:44 PM
I have been told that some of the newer stainless " kits " come withSS that can be double flared. and use 45 degree fittings. When I double flare ... I use a hydraulic flaring tool.
The hydraulic pressure makes a lot better fitting flare and I have not had any leak since buying this tool. It is not inexpensive ( about $300 ) but well worth it IMHO.
Old 01-30-2008, 06:39 PM
powerrodsmike's Avatar
Wiki Edits: 161
Soft annealed stainless tubing can get double flared at 45* .
I've done it. I don't advise doing it
Several companies are selling the tubing, Speedway has some, I believe that one of the specialty tubing companies does sell it also.
It is very hard on the flaring tools, you can't use a cheap one, I've messed up several good ones doing it. That Mastercool tool is a good one, Snapon and the other tool guys sell a similar tool.
Here are a couple of threads on the subject..
Flaring Stainless
Flared stainless brake lines
Hope this helps..
Mikey
BE different....ACT normal.
Double flare brake line problems highway 1011 Suspension - Brakes - Steering 8 10-21-2008 11:47 PM
Brake lines C10 wickedwitchinak Suspension - Brakes - Steering 4 08-07-2004 07:04 PM
brake lines too short after suspension rebuild FiveFeezy Suspension - Brakes - Steering 4 03-10-2004 09:25 PM
Chrome brake lines??? T5Bird Suspension - Brakes - Steering 6 02-16-2004 09:05 AM
Brake lines for conversion kit??? ChevyLuv Suspension - Brakes - Steering 9 09-26-2002 08:36 AM
