stainless screws - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-26-2010, 08:03 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Here is a place you might want to look at. I do not have a sales pitch about them, other then I have used them and the service was good.
http://stainlesstown.com/index.php?cPath=59
  #17 (permalink)
Old 11-26-2010, 02:09 PM
35terraplane's Avatar
Stainless steel
Originally Posted by redsdad
Rub 304 or 316 with a piece of carbon steel or use tools such as a file which has been used previously on carbon steel and then see what happens. It will rust.
SS does not rust as you think of regular steel rusting, with a red oxide on the surface that flakes off. If you see red rust it is probably due to some iron particles that have contaminated the surface of the ss and it is these particles that are rusting.
This applies to the 300 grade of ss the 302 303 304 304L 316 316L And so on, now this ss can get a stain on it but it is not easy to do . these grades are used for knifes, medical things, jewelry and much more. these also give you the best shine.
The 18/0 is the 400 grade 416 440a 440b 440c And so forth they will rust some because they do not have the nickel in them they are also much stronger than the 300 grade. the 400 grade is also magnetic, so the myth that ss isn't magnetic is just that a myth.
17-4 ph is one of the strongest ss used on aircraft, lots of military things.
there are over 150 grades of ss but we only use about 30 of them.
Bob
Need headlight buckets that align with screws from the back, or just longer screws grobb284 Hotrodding Basics 2 06-28-2009 10:06 AM
Flaring Stainless sha_ba_do_bang Garage - Tools 7 11-26-2005 10:17 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
Questions about stainless steel brake lines ckucia Suspension - Brakes - Steering 14 06-13-2005 08:26 AM
Idle mixture screws only turned out 3/4. Runs good. BrackneyC Engine 1 04-28-2003 04:58 AM
