Over kill, but if it's cheap, then go for it.
Trees |
ss tank
wonder'n if the tk has a stamp on the working pressure it's been ck'd for ???? if there is not pressure rating u may want to get that done.. for safety sake... it shouldn't be a problem but to feel better afterwards... hydro test it mainly after u have added any weld on fittings..
IMO there are three contaminates to worry about when painting. Water, oir, and particulates. Stainless will work great for reducing particulates, but that is the easiest comtaminate to remove with air filters. I think that if its cheap enough, then it will work as good as copper for air lines, but it will be more crush resistant.
That's easy.....COST!!! Jump on that thing before someone else does, you have come across a real jewel don't let it get away!! |
Thanks,thats what i figured why,is the high cost of stainless.
I'll be startin the procedures come tuesday to get it,but i don't expect to get a price/answer untill the end of october,we are in Pre-Outage right now preparing for a refuel outage september 18th and it's high priority and no one will have the time to go through the process untill after the outage. One thing have always noticed about stainless tanks and pipe is it sweats alot more than steel,so i'm thinking it'll also make a much better water remover in the lines too |
Well actually steel does not "sweat", it only collects water from the air if it is cooler than the surrounding air so in that respect stainless is no different than any other steel. Stainless may have better heat dissipation properties than regular carbon steel, really haven't thought about it, but once it has cooled to the ambient air temperature it will collect no more water than any other metal including copper, bedsides if it does have better cooling properties (radiates heat more efficiently) that's a plus! |
I think the reason i see more sweat on stainless pipe is because stainless doesn't transfer heat too well,so it stays alot cooler than mild steel. It takes alot less amperage/heat to weld it because of this,alot less heat sink because it won't transfer the heat away from the weld easily and rapidly. But then on the other side of it,stainless takes alot longer to cool down because it will hold the heat longer once its hot..lol I'm just having some "brain farts" here but it all doesn't really matter because i'll be adding filter and dryers So i think it'll make for some good air lines because they will cool the air more rapidly through the lines,but,any which way i'll adding filters and a good dryer for painting |
Your thoughts are right as it turns out, I reseached and found this.
http://www.engineeringtoolbox.com/th...ity-d_429.html So iron pipe would be three times better than stainless for the air lines, but copper is way better than anything. A desiccant air dryer will do the job, but the more moisture you can get out before it gets to the air dryer, then the less often you will have to service it. |
| Recent Garage - Tools posts with photos |
| OEM or Stainless Steel Fuel Lines? | 64 Impala SS 96 | Engine | 6 | 03-14-2008 07:05 AM |
| Stainless Steel Brake Lines | Blazin72 | Suspension - Brakes - Steering | 2 | 10-27-2005 10:45 PM |
| Questions about stainless steel brake lines | ckucia | Suspension - Brakes - Steering | 14 | 06-13-2005 07:26 AM |
| Flaring Stainless Steel Lines | blacklotus | Suspension - Brakes - Steering | 8 | 03-20-2005 07:52 AM |
| Advantage of having Stainless Steel Brake/Fuel Lines??? | djjc76 | Suspension - Brakes - Steering | 5 | 09-30-2004 07:44 AM |
