I want something at least equivalent to a grade 5 for alt, ps, wp, intake, etc.
For non structural stuff, like pans, any will work. It is a stress free environment. I use only grade 8 stuff in structural components. Inside engines either factory or ARP only. Any steering/suspension components in stainless MUST be THE BEST $$$$. Right now I am not trusting any bolts made in China, period. and I am not very enthusiastic about the rod bolts that come in rods but others have not complained yet. You will have to ask the manufacturer about psi ratings and their grade equivalent. Buying a prepackaged kit from Jegs or Summit might be fine for all the pans, headers, etc. Last edited by ScoTFrenzel; 10-11-2008 at 05:21 PM. |
The 17-4 PH, and the 18-8 are stainless steel types used in internal engine structural parts for aircraft and ground based turbines. The PH means that is is a heat treatable metal, and after heat treating they are extremely strong. I used to work at an investment (lost wax process) casting foundry that used these metals a lot.
Don't use stainless where the critical load is in tension. SS stretches in tension and loosens quickly. I found out the hard way... I used SS bolts on my steering box, torqued to spec. Within a few hundred miles the steering box was flopping around and I was bouncing off the guard rail on the freeway
Fortunately, no serious damage.
There is good information in this link:
http://www.enginebuildermag.com/Arti...ner_facts.aspx Scroll down to the section titled "Materials". tom |
What they all said. There is a company called Totally Stainless
that sells high strength ss bolts, supposedly as strong as grade 8. Don't go cheap, strong SS costs alot. Mcmaster Carr lists the tensile strength of all of their fasteners, compare the tensile strength of the SS bolt you want to a steel grade 5 or 8 . From my Mc master's catalog... Grade 8 alloy steel is 150000 psi Grade 5 is 120000 psi 316 SS is 70000 psi. 18-8 is 70000 psi Some of the 316 metric screws are rated higher, 100000 psi You need to compare the screws you are actually going to use. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 10-11-2008 at 05:48 PM. |
Ever heard of ARP?
![]() Quote:
And you don't learn about the little details either.Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
17-4 PH has a 180,000 psi tensile strength. We use these fasteners regularly in aerospace applications. Other stainless has lower properties, as you have noted. This is why the stronger bolts are more expensive. If you have an application with Grade 8 bolts currently, DO NOT use anything with a lower tensile strength. As for the discussion about stainless loosening on a steering box, this is either because the bolts used had too low a yield strength or locking nuts were not used. The rated strengths (tensile yield, ultimate, and shear) as well as the stiffness of metals are all listed in MIL-HDBK-5, which is available on line. |
Joe P-
Is this a good online source for the Mil spec 5 handbook ?http://www.grantadesign.com/userarea/mil/mil5.htm It seems to have a wealth of information about materials, the processes involved in different treatments, and explanations of the various terms used . Later, mikey
There is also MIL-HDBK-17, which covers non-metallic materials, including graphite, fiberglass, and kevlar. That data DOES change fairly rapidly, so you do want to find the latest version. |
Stainless tends to gall when the threads are run into anything, but especially aluminum and other stainless. This increases the friction within the threads and gives a false high side torque reading when bolting things together. It's a darn good idea to always use anti-seize or Loc-tite in the threads, this gives a more representative reading between torque values and actual clamping force and in the case of Loc-Tite helps prevent vibration from loosening the fastener. For the most part, stainless is perfectly suitable for engine exterior use where the loads are reasonably low and the need for corrosion protection and looks is high. Actually in this case the use of polished stainless is probably superior to chrome plated alloy steel as the plating process significantly weakens steel thru hydrogen embrittlement as H2 is taken up from the chromic acid bath into the steel during the plating process. ARP and Totally Stainless are two good sources of high strength or at least known strength stainless. Stainless from the home improvement center is probably made in China and is of both dubious corrosion resistance and strength. Bogie |
| Using Stainless Steel VS Steel | brainsboy | Suspension - Brakes - Steering | 5 | 11-18-2010 10:41 AM |
| SF oil???? | n-gin | Engine | 6 | 07-09-2008 01:37 PM |
| stainless steel u bolts | 5ohchevy | Suspension - Brakes - Steering | 2 | 08-12-2007 07:25 AM |
| Welding Stainless Steel to Hot Rolled Steel? | Rambo_The_Dog | General Rodding Tech | 11 | 05-07-2007 10:05 AM |
| Cam Help | black66 | Engine | 3 | 05-12-2003 06:15 PM |
