Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stainless steel lake headers
Old 01-04-2013, 07:52 AM
timothale timothale is offline
Wiki Edits: 27
SS headers
I have some SS 060 tube, 2 1/2 Dia that I was thinking of making my own cones from, cut a long triangle out then use several radiator hose clamps to pull it down to a cone and tack it. Stainless tends to grow clumps on the underside of the weld if you don't purge the area, seal it up the ends with foil air conditioning duct tape then fill with argon. I have a double flow meter for my tig, one for welding and one to control the purge gas flow.
