stainless steel lake headers - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2013, 09:19 PM
Last journal entry: gus`s 40
I was wanting to build another set of lake style headers but out of stainless steel. Does anyone know if there is someone who makes a cone or entire weld up kit?
Old 01-04-2013, 06:17 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I know there are stainless bends and tubes available in header kits but the cones do evade me..That may need to be a custom piece from a local fabricator..
Sam
Old 01-04-2013, 06:52 AM
Wiki Edits: 27
SS headers
I have some SS 060 tube, 2 1/2 Dia that I was thinking of making my own cones from, cut a long triangle out then use several radiator hose clamps to pull it down to a cone and tack it. Stainless tends to grow clumps on the underside of the weld if you don't purge the area, seal it up the ends with foil air conditioning duct tape then fill with argon. I have a double flow meter for my tig, one for welding and one to control the purge gas flow.
Looking for stainless steel Camaro BBC headers firebirder Engine 4 05-09-2011 01:33 PM
Stainless Steel Headers good or bad jjtrains84 Engine 5 04-11-2010 10:15 PM
Welding Stainless Steel to Hot Rolled Steel? Rambo_The_Dog General Rodding Tech 11 05-07-2007 10:05 AM
Stainless Steel Headers Kahibbi Introduce Yourself 2 10-07-2004 08:50 AM
Stainless Steel Headers Kahibbi Engine 4 10-05-2004 11:51 PM
