Stainless Steel Trim - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2007, 03:01 PM
Jim57's Avatar
Last journal entry: Engine compartment
I looked in exterior but they only talked about paint and bondo!
What I want to know is how to take the dents and scratches out of the trim pieces on my 57 Chevy.
Old 08-02-2007, 03:31 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
You can make a bigger mess by banging dents out by hand. I have seen several shops using a drill press (not running) , with special tipped homemade tools to push the dents out slowly.
The stainless is hard to buff scratches out. You need to go with many grits of sanding to get the scratches gone before buffing.
Then it was mentioned here that you need to brace the part onto wood, etc so the part doesn't get away from you with a high torque buffing wheel.
Old 08-02-2007, 03:49 PM
Holder350's Avatar
Auto Parts Professional
Years of experience. I worked for a while replating steel and buffing stainless and aluminum. The guy I learned from had done it for 15-20 years, and showed me how....but I never did get the hang of it.
Take them to a chrome shop and get an estimate, I know we charged $1 an inch (length not square) and any dings were like $5 a pop.
course we were considered CHEAP back then so I have no clue now
Old 08-02-2007, 04:24 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
There is a guy in Santa Fe Springs, Ca that did all of the stainless and aluminum on the 59 Elky in my avatar.
Not too unreasonable either----no web site
Ship the parts to him and he will call back with a price.
I am more than pleased with the stuff he did for me, not A-1 absolutely perfect (bed mouldings are long and flat--difficult to work with), but, more than good enough for an occaisional show.
That Elky has a LOT of stainless that is long, WIDE, and nearly flat.
I was plenty impressed with his work.
He even MADE a couple of mouldings that I could not find anywhere. The NOS or good used ones were over $500 a set. He made 'em for half that cost.
Might start by sending a few pieces, and go from there.
4"PVC sch 35 pipe makes excellent shipping tubes.
Bryan
Old 08-02-2007, 06:26 PM
Here it is, I have straightened steel grilles for chromeing, bumpers, all kinds of things. Stainless, even a Honda Belt moulding I folded in half a while back. It WORKS. However it will take some time to get up to speed. Pick up some old stainless moulding and do some repairs, even if you have to put some dents in it yourself.
“Basics of Basics” Molding straightening/metal finishing
By Brian Martin
When straightening stainless moldings you are "metal finishing" just as you would metal finishing a ding on a fender. The following method would only be used on small damage of course, but depending on the time spent, you could use the same procedure on a larger dent.
If you do this on a fender, you don't need filler of any kind. The art of metal finishing is not easy. But if you are doing it on these moldings, you are on the way to doing it on your dented fender or door.
The most important thing you want to remember is that when you file (a VEXON file for auto body work is the best tool) on something like this, it is more for spotting high and low spots than "cutting" those high spots. You run the file over the area then look closely to see what the file hit. If there are areas where the file hit hard, these are likely high spots that need to be tapped down a little before you proceed. You don't want to keep filing (or sanding) if you are hitting some spots hard and others aren't even being hit.
If there are spots that aren't being hit, those need to be brought up.
When there are large high and low spots a small hammer or rounded ended “chisel” can be used to “rough” it into shape. All the while, checking with the file, THAT is the tool to see where you are at.
I was taught to use a sharp tool like an awl to push up these low spots. It works well because the pressure is so localized. You want to push up from the back with an awl, and DO NOT MOVE where the awl is making contact. As you push up, the pressure is so localized you can usually see on the other side where you are pushing. If you are right on the money, go ahead and bring it up as much as you want. If you are off a little, you can move the awls tip over to where you think you need to be and apply pressure there, again, watching closely on the out side.
If you don't move where the awl's point is making contact, you can easily move it a little to where you need to be, remember we are likely talking about moving it an eighth inch or less, sometimes a thirty second of an inch. If you move the awl after pushing an area up, you may not be able to find that exact spot again. The point is (if you'll pardon the pun) to hold pressure on the awl where you pushed up as you look at the outside to see if you hit the right spot. If you do need to remove the awl to file, take a good look at the back and make a mental note of exactly where you pushed. That way you can go right back to the spot if you need to after seeing what the file is telling you. If you don’t move it, you can easily “slide” it over that eighth inch or less to the exact spot you need to bring up. What I do is hold the molding in my hand with my index finger and thumb. In the middle of my hand is the awl. I squeeze the molding pushing the awl up into it. My hand is upside down so the molding is facing up towards me. That way I can easily push up the low spot while I look at it from the other side.
The trick is, DO NOT file much, and just run it over the surface until you can see the high and low spots. After you have worked the area to near perfection, you can file a little more to knock down highs to make it perfectly flat for sanding and polishing. But if you rush this identifying of high and low spots and think you can file the damage away, you will end up with too thin of metal and blow the whole thing. When I was learning, I even went thru the metal a time or two. It is easy to do if you ask the file to do too much. The file should be looked at as a straight edge, more than a cutting tool.
This process can be long and tedious, you must take your time or you will do more damage than good. If you push up a little too much, just tape it down and try again. We are talking moving the metal a few thousands of an inch or so. Don’t move the metal so much as to make a visible “dent”. Most of the time you will barely be able to see where you moved it (thus the importance of not moving the awl) only the file will tell you if you did or not.
Now, once you get the area flat, you have filed it and the file says it is FLAT, you need to sand the file marks out. This is a trick I thank one of my mentors for. I have shown this to many bodymen and they will always be amazed at how good it works. You need a DA, a good old DA that you can lock the head to a grinder mode. Not an “orbital” sander, but a true “Dual action” sander. My favorite is the National Detroit “DAQ”. This tool is the best version on the market in my opinion. It has the most torque using he least amount of air.
Ok, you have listen to a story. I mentioned I have shown this trick to many bodymen, well the last time I did, it cost me. I had a nearly brand new DAQ (my last one lasted 25 years!) that I used to demo this procedure on a door skin a co-worker was doing. I was helping him with a problem door and when we came to the point of metal finishing the skin he went to grab his air grinder with 80 grit, NO, NO, NO, wrong tool! I went to my box and grabbed my DAQ with some 120 and quickly knocked the thing down flat and beautiful. There was a few guys there by this time and all were amazed at how well this worked. Well, one of them liked it so much they thought they would “trade” their worn out DAQ for my brand new one. Yep, a few days later I went to use my DAQ and found that in my box was not my new one, but an older abused DAQ!!! To this day I have not found my nice new DAQ, I suspect it is in one of my “buddies” garages at his home.
Ok, here is the trick, you use the DA pad as a 6” “block”. If you put the DA on grinder mode with some 600 or 800 on it you can hold it flat as you run it over the surface, favoring the left to right direction. The disc is turning clockwise, so you want to run the disc over the area hitting ONLY the top half of the disc on the metal, against the rotation of the disc. This top area is flat right? It is one half of a perfectly flat circle, so it is in effect a “block”. On this stainless you would use the 600 or finer to “block” it. On sheet metal you could start with 120 or 180, and prime over that. If it was going to be chromed like a bumper that is thick metal, you could still use the 120 or 180 and then move on up to 600 and leave it, the chrome shop will take care of the rest. Heck, I don’t think they use anything finer than that anyway.
I have used this method on stainless steel moldings, steel being chromed, thick steel like bumpers being chromed, sheet metal parts like fenders or doors being primed and painted, it WORKS.
The neat thing is, when I was taught this trick back in the seventies, the finest paper you had was 600. Now, with paper all the way up to 3000, you can REALLY do some trick stuff. I had a set of aluminum wheels to sell on eBay. They had some curb rash on the bead. I used this method with 120, 180, 320, 600, 1200, 1500, 2000 and then polished it to a fine luster. It really works well, give it a try.
Old 08-03-2007, 04:55 PM
Jim57's Avatar
awls and rasp won't do
Thanks for the reply but I saw this thread.The stainless trim on my 57 is much too light weight to be pressing out dents with something as sharp as an awl or as coarse as a rasp.
Thanks,
Jim
Old 08-03-2007, 05:22 PM
I have repaired those exact mouldings with this technique. The thing is, take it easy, you don't the awl with a hammer, you push on it. You could push a sharp awl against your arm and not hurt yourself, or you could push it will a lot of force and run it right to the bone. It is all about about how much force you use. The cool thing is, with the awl, you have TOTAL control on how hard you push, but more importantly you can zero in on an EXACT spot.
Stainless Trim: Generic Sources or How to Extrude? Rambo_The_Dog General Rodding Tech 14 11-22-2007 10:20 AM
Welding Stainless Steel to Hot Rolled Steel? Rambo_The_Dog General Rodding Tech 11 05-07-2007 11:05 AM
Are there any guides to making stainless steel trim? Slipangle Body - Exterior 1 08-10-2006 02:52 PM
Questions about stainless steel brake lines ckucia Suspension - Brakes - Steering 14 06-13-2005 08:26 AM
Reparing Stainless Trim.. How? bigfred1958 Body - Exterior 3 11-05-2004 09:52 PM
