Stainless Steel tubular A arms...??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2010, 11:44 AM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Anyone has ever made A arms out of schedule 40 304 stainless steel tubes?
I want them for my dune buggie, I was to make them out of mild steel but I think it would look great if made of stainless steel.
please comment.
Augusto.
Old 10-19-2010, 01:07 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I believe the type 304 is mostly for decorative purpose..fine for a bumper or firewall..the 1018 mild steel is better to use for your a arms..
Sam
Old 10-19-2010, 01:26 PM
Augusto's Avatar
actually 304 is very strong, much stronger than 1018 and does not brittle when welded like the high strength cromoly, this is why I'm considering it, but I may be wrong.
Old 10-29-2010, 02:58 AM
327NUT's Avatar
I have polished SS tubular A-arms on my '32 TCI chassis. They have been using them for a long time...don't know which SS though.
Old 10-29-2010, 06:00 AM
Will I ever get it done?
Last journal entry: Hood
SCH 40 is not tube, it is pipe. Both are available seamless or welded. All 4 varieties have roughly the same strength. I think the tube would be easier to finish. While the pipe may look smooth, when you start to polish it you will probably see "orange peel" from the manufacturing method. I am assuming you probably have some 304 SCH 40 pipe already. I think you would be happier with tube. Just my $0.02.
Old 10-29-2010, 11:54 AM
35terraplane's Avatar
SS tublar A Arms
redsdad is right it is pipe, which could have a ridge on it. 302 or 304 are tough SS you don't consider most SS hard, it is really gummy but very tough. that's what makes it harder to turn than other metals, 416 SS is harder than 302, 304, and easier to turn. 416 is also magnetic. one of the strongest, use on aircraft a lot, is 17-4 ph, ph stands for precipitating hardness. It would be the best, but it does not give a shine like the 302-304. and hard to work with. 303 would be a little to soft, I don't think it would take the hitting of bumps or the like. 302-304 is used in the medical instruments world, along with aircraft.
35terraplane
Old 10-29-2010, 01:46 PM
Irelands child's Avatar
These are TCI and supposed to be 304L:
http://www.aksteel.com/pdf/markets_p...Data_Sheet.pdf
Dave W
Irelands child
Old 10-29-2010, 02:05 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
400 series stainless gets brittle when welded.
304 stainless with 308 rod TIG welded is very strong.
I have some pics below of my upper arms.
I believe I used sch 80 1-1/2" type 304 pipe.
The inside is going to warp like crazy when you weld it so it will need to be reamed.
Edit: The sleeves are sch pipe. The arms are 1/8 wall tubing.
ID:	49370   Click image for larger version
ID:	49371   Click image for larger version
ID:	49372   Click image for larger version
ID:	49373   Click image for larger version
Using Stainless Steel VS Steel brainsboy Suspension - Brakes - Steering 5 11-18-2010 10:41 AM
Are there any guides to making stainless steel trim? Slipangle Body - Exterior 1 08-10-2006 01:52 PM
Stainless Steel Brake Lines Blazin72 Suspension - Brakes - Steering 2 10-27-2005 10:45 PM
Stainless Steel Sheet work Dragon J Body - Exterior 8 03-15-2003 07:48 PM
Tubular control arms M&M CUSTOM Suspension - Brakes - Steering 0 03-14-2003 02:23 PM
