Stainless Valves or Not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2009, 02:42 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I have a chance to get some recently redone 781 heads for my 454. The valves come with the heads but are not installed yet. Is there a way to tell if the valves are stainless or not? Can I use a magnet to tell? Also, the guy says the guides have "liners" instead of bronze guides or knurled. Is this acceptable for a performance build?
Thanks
Old 04-27-2009, 03:55 PM
Thanks
- A guy that says they have "liners" instead of bronze guides, needs to be more descriptive. Typically press in guides are either some sort of a bronze alloy or are cast iron, either is suitable.
- Some stainless alloys are magnetic some aren't. Valves will be of some sort of stainless alloy unless made of titanium.
- General description of the more common stainless alloys:
*Austenitic: Chromium-nickel-iron alloys with 16-26% chromium, 6-22% nickel (Ni), and low carbon content, with non-magnetic properties (if annealed - working it at low temperatures, then heated and cooled). Nickel increases corrosion resistance. Hardenable by cold-working (worked at low temperatures) as well as tempering (heated then cooled). Type 304 (S30400) or "18/8" (18% chromium 8% nickel), is the most commonly used grade or composition. Grades run from 100 thru 300 series
* Martensitic and Ferritic, these are 400 series.
Martensitic: Chromium-iron alloys with 10.5-17% chromium and carefully controlled carbon content, hardenable by quenching (quickly cooled in water or oil) and tempering (heated then cooled). It has magnetic properties. Martensitic grades are strong and hard, but are brittle and difficult to form and weld. Type 420 series is an example. Ferritic: Chromium-iron alloys with 17-27% chromium and low carbon content, with magnetic properties. Type 430 series is an example.
*There are other grades in the 500, 600, 700, and 900 series. Inconel is one in this series that's often used in valves it's actually an austenitic type, very difficult to form thus expensive, but really good stuff.
Valves need different qualities (especially the exhaust) between the head and stem. The head is usually a cold worked ferritic steel for its strength at extreme temperatures while the stem needs to pass heat to the cooling system and resist wear so they are usually the martensitic alloy. The stem is then friction welded to the valve head by spinning them at high speed and slamming them together with extreme pressure. Other processes are used on better quality valves to put hard wearing surfaces on the seat area like Stellite and sometimes a hard tool steel wear cap on the stem end to increase wear life against the rocker arm. Stems often are available with a hard chrome finish to assist in wear quality. My personal like is for chrome against bronze alloy guides as chrome doesn't oil wet well and bronze is better at becoming oil wet than cast iron, so with positive oil seals on the guide, I prefer the bronze guide, chrome stem combination with lifts about a half inch or more.
- Go here for Manley's descriptions of their products which leads you from common street valves to uncommon race hardware.
http://www.manleyperformance.com/dl/2008/valves.pdf
Bogie
Old 04-27-2009, 04:09 PM
cranky1's Avatar
Just stuck
Good info there! Don't think I've ever read something like that before...
Old 04-27-2009, 04:22 PM
S10 Racer's Avatar
Well, he says the liners are "steel" but exactly what that means is unknown at this time without seeing them. The heads do have 2.250 intake valves and 1.88 exhaust. Do these size valves come longer than stock? I already bought a set of stock length pushrods from Comp Cams but thought I might buy these heads as they are 781's and all the work has been done to them but as I search the internet, I see where most all 1.88's are .100 longer and the 2.250 are .250 longer than stock. Will I need to buy different pushrods to use these valves?
Old 04-27-2009, 04:31 PM
ericnova72's Avatar
More for Less Racer
As far as the pushrods go, you are not going to know what the correct length will be until the trial (or final if you are only doing it once) assembly. That is why pushrods are the last pieces bought in a performance build. There is no good way to know ahead of time what they need to be. The valves you have listed can be bought in many different lengths including stock length. Competition Products lists 2.25" in stock length, +.050", +.100", etc.
Old 04-28-2009, 10:06 PM
4 Jaw Chuck's Avatar
All stainless automotive valves are magnetic, just not strongly so. The non-magnetic stainless series of alloys are unsuitable for valves in a automobile engine.
Lined or sleeved valve guides are usually bronze sleeves that are swaged in place using a ball bearing to size them at the same time. They are very durable and since they harden the bronze surface once swaged into place are actually preferable to thread in types or pressed in. They actually get a mirror finish when they are placed.
K-Line is a very popular brand.
Never heard of steel liners, perhaps he means cast iron which are pressed in.
Old 04-28-2009, 10:30 PM
DaSouthWon's Avatar
I put up the tools against$300
If you want to know if they're stainless or not get em' wet. If they're not stainless they will rust....
Lapping New Valves - Help leejoy Engine 11 11-10-2007 08:56 AM
Stainless steel SBC valves gcrmcc Engine 11 08-07-2007 08:12 PM
Adjusting Valves and Fuel Pump Install demitristewart Engine 5 08-09-2006 10:10 AM
EV-8 stainless steel valves "HELP" 406 ss monte Engine 5 12-17-2004 02:34 PM
stainless valves ?? russ 61 Engine 4 12-30-2003 07:02 PM
