Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - stake pocket holes
Old 08-28-2005, 09:40 PM
gofast51 gofast51 is offline
slammed88
If you have stake pocket holes now and you want to shave them? Yes,you cut a pattern to fit out of poster board and transfer the pattern to the metal.Cut it out and spot weld around the patch until it's complete. Use 18 gauge steel because that is the closest to what the rest of the sheet metal is.Then grind smooth,epoxy primer,two part filler,sand,2k prime, guide coat.block ect....
