stake pocket holes - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2005, 09:22 PM
stake pocket holes
if you have shaved stake pocket holes before how did you do it, just cut a piece of metal and weld it in even
Old 08-28-2005, 09:37 PM
rrmccabe's Avatar
GM Muscle
Exactly. You probably want to lean towards a little low with your filler plate. Easier to fill that way.
Rich
Old 08-28-2005, 09:40 PM
slammed88
If you have stake pocket holes now and you want to shave them? Yes,you cut a pattern to fit out of poster board and transfer the pattern to the metal.Cut it out and spot weld around the patch until it's complete. Use 18 gauge steel because that is the closest to what the rest of the sheet metal is.Then grind smooth,epoxy primer,two part filler,sand,2k prime, guide coat.block ect....
Using Muggyweld/lead for pin holes Slickriffs Body - Exterior 2 10-01-2004 10:07 AM
Filling Holes Ron M Body - Exterior 2 09-11-2004 04:04 PM
Weld Pin Holes and Body Filler Ron M Body - Exterior 3 08-25-2004 03:15 PM
Filling holes on a '56 Mercury roof Slipangle Body - Exterior 5 07-27-2004 07:32 PM
Filling up holes in body, including rust holes Mr.56Chevy Body - Exterior 5 12-12-2002 12:55 PM
