Stale A/C smell - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2012, 02:38 PM
mitmaks's Avatar
Last journal entry: Grille
Stale A/C smell
When a/c has been working and then turned off there is this stale smell in cabin. Is there a way to fix this?
Old 09-22-2012, 05:57 PM
Wiki Edits: 27
drain ?
there should be a drain hose for the condensate, If it is plugged the moisture goes sour, MY F350 doesn't completely drain, I've heard of some guys running quite abit of water down the air intake for the heater to try to flush it out, adding a bit of bleach and letting it sit then flush again to get the bleach smell out.
Old 09-24-2012, 07:37 PM
It is caused by mold spores that get into the evaporator core as the warm moist air from the outside moves through the evaporator core. when you shut the vehicle off it is dark and moist in there, so the bacteria & mold grow. When you first start it up again get the smell. Sometimes you can turn on the a/c with the blower on and spray Lysol into the inlet duct where the outside air is drawn in. It will kill the mold. You can also buy a disinfectant specificly made to disinfect the A/C. It usually works
Old 09-24-2012, 08:01 PM
mitmaks's Avatar
Thanks, I'll try that next time it smells like dirty socks
Old 09-25-2012, 07:00 AM
302 Z28's Avatar
If your car has a cabin air filter change it.
BVince
Old 09-25-2012, 10:07 AM
All of the answers above are correct although I don't think I would put a garden hose into the air intake. Make sure the drain on the bottom of the evaporator box is open. If not open take a wire with a small hook on the end and try to open it up. If you pull out a significant amount of gunk you'll probably have to pull the heater case out and clean it. Plugged heater cases usually happen when a vehicle is parked under trees regularly or dog hair or even mice! If everything is clear and open the product you want to use is called Ozium. You can get it at any parts store. In the future when using your a/c set it to outside air rather than recirculated air.That will help the box air out .
Old 09-25-2012, 10:10 PM
I once had an Astrovan with a similar issue. Lysol does help. It needs to be applied periodically, but will help to kill off the mold that has developed.
PatM
mouse smell swvalcon Interior 18 03-14-2012 07:11 AM
Gas smell jamesoravetz Hotrodding Basics 2 02-02-2009 03:23 PM
Stale BB? DaSouthWon Engine 7 04-17-2006 10:03 PM
Oil smell kc_ksom Engine 6 11-13-2005 06:01 PM
What's that smell? jcclark Body - Exterior 3 11-09-2005 02:43 PM
