stall converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2006, 08:19 AM
stall converter
how can you tell if your stall converter is bad or going bad???
Old 12-31-2006, 09:55 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
When the $%^&* explodes at 6000 rpm and cuts your foot off...... that's one sign ..
X
Old 12-31-2006, 10:20 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
If you post more then one sentence I'm sure someone here will be able to help you out. (without being sarcastic )
Old 01-01-2007, 09:27 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Converters will do one of twos things..... the RPM stall gets low or higher.....If the converter is equipped with a sprag and this fails there will be a RPM change in how the converter stalls & acts.
In some cases the transmission of power stops completely.
Not too often the converter actually explodes , but it has happened.
Old 01-01-2007, 07:54 PM
stall converter
What is your car doing or not doing?
Old 01-01-2007, 08:02 PM
valve body kits
hehe.. well actually, 1 sentence is sufficent for a 1 sentence reply.. for example...
Q "how can you tell when your stall converter is going out?"
A "when it no longer works correctly!"
but the 3 most obvious indicators would be..
1.. the trans is getting loaded with metal particles, and
2.. the stall is getting higher, and
3.. noises that shouldn't be.
Old 01-01-2007, 08:08 PM
xntrik's Avatar
converters...
This is a double post from the ENGINES forum....
where he was crabbing that everybody over here ignored him here........ when this thread was only 10 hours old......
Old 01-01-2007, 08:17 PM
stall converter
Well he's getting plenty attention now!
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 01:42 PM
what would be the best stall converter for me? tiresmoke55 Transmission - Rearend 3 08-30-2006 04:42 AM
please recommend me a stall converter smlblcks10 Engine 6 02-09-2005 06:41 AM
checking stall on converter Checy_Guy Transmission - Rearend 1 07-21-2004 09:06 AM
Hughes 2500 stall converter s15laynrubba Transmission - Rearend 0 08-10-2003 12:36 PM
