Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stall Converter
Thread: Stall Converter
Old 12-29-2005, 11:23 AM
Ozz1967's Avatar
Ozz1967 Ozz1967 is offline
Air Force Guy
Originally Posted by sbchevfreak
Your "stall" speed is the maximum engine rpm attainable with the trans in gear, and the output shaft stationary (brakes on, wheels not rotating). If it is higher that rated, the trans is slipping, lower could be engine tune, ect.
This actually makes the converter like a clutch in a standard trans car, locking the turbine to the converter housing for a near 1:1 drive. 1500rpm stall or 3500 rpm stal, at lock up they will both act exactly the same.
Ozz, at 45mph, O/D is a normal gear change. If you don't want it to shift into O/D, drive it around town in D.
Yeah, I keep it in drive around town when I want to be a bit more "sporty". I just don't know which converter to buy. The specs at comp cams say 3000 stall, others I talk to say for a street car you shouldn't need anything over 2500. Any suggestions?
