stall converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2006, 08:59 PM
BadS10's Avatar
stall converter
my friend has a 99 gmc sonoma it has a 350 c.i chevy small block.hes runnin about a 12.0 to 1 compression ratio 450 to 500 hp and 450 lbs ft torque he has a 373 rearend turbo 350 trans with a pro street shift kit,what size stall should he use it has a cranne energizer 500/500 302 duration 3500-6500rpm range wants to be dependable to drive through town
Old 02-06-2006, 09:13 PM
Need cam specs for correct choice
Old 02-07-2006, 12:34 AM
if the cams rpm range starts at 3500 then stall speed should be 3000+ but i sure as hell wouldnt dirve it around town! unless he just has lots of cash to throw in the gas tank. the converter wont really lock on untill the stall speed, so if your cruisin at 2500 rpm your just wastin gas and killin your trans. hope he has more than one vehicle to drive to work!!
Old 02-07-2006, 09:45 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
That just makes me laugh. Let's see, 4 MPG, idle around 1100, no vacuum for brakes, climate control, or ignition advance, and an empty bed that won't give traction on the stock 4-banger. Sounds like a fun ride
Old 02-07-2006, 04:20 PM
rsafreed's Avatar
Torque Convertor
I have a 350 Chevy with a 3.70 rearend and a TH350 high stall convertor. (11"- 2500 Stall) works great on the street. You'll love it. To much stall and you'll slip and slide around town..
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
please recommend me a stall converter smlblcks10 Engine 6 02-09-2005 05:41 AM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 03:04 PM
checking stall on converter Checy_Guy Transmission - Rearend 1 07-21-2004 08:06 AM
Stall Converter novatech Transmission - Rearend 2 07-21-2003 09:24 AM
