Stall converter confusion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2012, 06:10 PM
Hi folks, I'm building a '50 studebaker rat rod p/u. It came with a 350 chevy 30 over, flat tops, 2.02 heads and 600 holly hooked to a 350 turbo with approximately 373 gears. Here's the bad part the cam is one of those huffing and puffing wide duration cams but I have no idea what. I would guess from it's extreme rough idle it must be a 292 advertised or more. Problem is it also came with basically stock converter. At idle in gear,the engine just barely runs, loaping and wanting to take off. So I ordered a b&m 2400 stall. It came, i put it in and much to my surprise not much change. This was one of b&m's cheaper line. So this time I thought I would do a little more research. The engine idles at 1000 rpm's ( wouldn't get much lower), drop it in gear and it slows to 800 rpm's, power brake it and the wheels spin at around 1800. Now I'm trying to figure out what brand and size stall converter to go for. My confusion and ignorance comes in the area of what benefit in idle do you get as you increase the stall. It is the rough idle I'm trying to overcome without causing a problem with slippiing at normal driving. I'm considering around 2600 to 2800. Any help would be appreciated.
Thanks
Old 08-07-2012, 07:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
The ignition timing is at the root of it all. Basically you want a LOT of initial timing and a short mechanical advance. That allows the carb primary throttle blades to be closed where the transfer slot is exposed the right amount. If the throttle blades are open too far, the transfer slot becomes the main idle air/fuel mixture supply and this will cause a poor idle and off-idle transition.
There are many posts here on this subject if you want to do a search. Also you can read the info here and if you still have questions, just ask!
Holley primary idle transfer slot
The drawing below shows the primary idle transition slot as seen with the carb held upside down. The drawing on the Left shows an overexposed transition slot. Baseline the throttle blades to give a transfer slot that looks like the image below, Right:
Other carbs have similar transition circuits, and they need to have the throttle blades in the 'sweet spot' same as the Holley. If the throttle blades are open too far, a poor idle and off-idle transition can be the result.
Old 08-08-2012, 03:42 PM
Thanks fellows, I ordered the hei curve kit today and will follow your advice. thanks again.
Old 08-10-2012, 06:49 AM
Last journal entry: Still running strong
When driving it,at what rpm does the engine come on cam,or worded another way,at what rpm can you start to feel the torque comming on.Mine started at 2800 rpms so I bought a 2700 stall converter.You dont really get any benefit at idle with the torque convertor,you want the t/q to kick in when you come on cam.What is your vac.reading at idle,if its low say around 10 to 8ins.then you have a big cam.Ive got a mid level cam and my vac.at idle is 14ins.
Old 08-10-2012, 07:49 AM
get a vigilante converter and never look back
3200 is the one i got and i love it
Precision Industries
stall conv confusion runndmy Transmission - Rearend 3 11-06-2010 11:47 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
Converter confusion... Greg T Transmission - Rearend 5 07-14-2007 09:26 PM
stall converter chvy454sschvll Transmission - Rearend 2 03-31-2006 09:17 PM
Do we need a stall converter? raidmagic Transmission - Rearend 16 04-29-2005 08:43 PM
