Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Stall converter suggestions
Old 01-13-2013, 04:42 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
are you using slicks or street tires? 2800 - 4200 stall.Im guessing your shift rpm around 6200? If you use a higher stall and street tires the car will be difficult to hook up.If you are using slicks the 3.55 gear ratio is not much for a hard launch.
