Stall Converter suggestions for my application? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2013, 09:41 PM
I recently put together a 327 for a 69 chevelle. its for the street, came in 2000-6200 rpm operating range, turbo400 trans and a 3:73 gear for rear end. all stock steel body. i dont know if im in the right forum for this but im not sure what size stall to use for this motor. please help
Old 04-21-2013, 09:45 PM
Banned
most off the shelf converter stalls are listed from a formula of being behind a 350cid
so a 3000 stall might stall at 2600 with a 327
street use I'd go with 2500-2800
Old 04-22-2013, 01:03 AM
vinniekq2's Avatar
racing or just street use? is the motor making any power?whats the rear gear ratio
Old 04-22-2013, 04:24 AM
Banned
must've been a long day for you..
he said for street and 373 gears..
didn't list seat of pants dyno # or tire dia..
Stall converter suggestions jtz55 Transmission - Rearend 9 01-14-2013 06:56 PM
Street- strip torque converter stall rating suggestions tcn71nova Transmission - Rearend 10 11-20-2011 07:30 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
How much stall is ideal for my application? Stupido1 Transmission - Rearend 3 03-25-2005 12:42 AM
Torque Converter Application BMRIde85 Transmission - Rearend 4 06-17-2004 02:57 PM
