stall converter or transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2007, 06:05 PM
I have a 67 chevy short wheel base truck which has built from scratch. it has a 67 corvette 327/385 horse engine with disc brakes all the way around. electric cooling fan. have a 400 transmission with 3800 stall convertor with 373 positive rear end. it has been park for almost a year now because i dont know what it is the transmission or stall converter. when it did run it would run perfect for about 20 minutes then the transmission would go out. it would not move. then it cool off and run again. now when i crank it and let it idle in the yard and then put it in gear the truck dies. can somebody please help me and let me know whats the problem. one more thing the transmission fluid is black and i know thats a bad sign.
Old 08-06-2007, 07:40 PM
Roddin in OK
Last journal entry: Still Moving Forward
tranny problems
i have alot of experience with GM trannys and there hard to diagnose just by hearing a few symtoms. but it's weird it sounds like the first problem you had was with the tranny end of it, and the second symtom was the convertor. which ever it is it sounds like a rebuild is in the cards. if it was me i would NOT use a convertor with that much stall the last 400 i used i put a t-350 convertor in it. they interchange but the 350 has a higher stall than a stock 400. mine was behind a 350 horse small block and it worked great. as far as getting off cheaper with a good rebuild look for a good size transmission parts house and ask them if they recommend anyone. the one where i live has a few they recommend that have done them long enough to know there not a fly-by-night,there rep. is on the line and so they'll steer you right and it's a cheaper way to go. good luck
Old 08-07-2007, 12:53 AM
my brother and i built the truck and it was goin go be for drag racing until he got sick with diabetes and things. i know that stall is too big. i will have it check out and see whats wrong with it.
Old 08-07-2007, 04:52 PM
re: stall
Hey bigtank05, this is deno. the stall is to high. 3800 is for cars with 900 HP. You should use a B&M #BMM-20412 2300-2500 STALL. I have a 3200 stall in my Camaro. 700 HP. With a supercharger. Thanks deno----
Old 08-08-2007, 02:35 AM
thanks. so about 2800.
Old 08-08-2007, 03:18 PM
re:stall converter
Hey, this is deno again. I took out a TH-400 and a BMM-20480 Nitrous Holeshot 2,400 stall from my Camaro. If you want you can call me. #732-580-0908. Thanks deno---
Torque Converter Stall Speed leejoy Transmission - Rearend 2 09-17-2006 10:43 AM
what would be the best stall converter for me? tiresmoke55 Transmission - Rearend 3 08-30-2006 03:42 AM
torque converter problems Blob Transmission - Rearend 9 05-05-2006 02:57 PM
good stall converter? camaro409 Transmission - Rearend 1 06-26-2004 06:22 PM
Stall converter? 79ElCamino Transmission - Rearend 3 06-05-2003 07:16 PM
