stall convertor - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2010, 08:22 PM
stall convertor
I am having a heck of a time with a 2400 stall converter its stall the car one time them works fine the next. Will low transmission fluid give this problem or have I just got a piece of crap for a converter?
OLDROD
Old 06-23-2010, 07:07 PM
OLDROD
I see about 25 or so people checked my post do we not have any one who is knowable on automatic transmissions and converters ? oh the tranny is a FORD C4. The problem seems worse when I have to stop for lights or stop signs and things are hot.Any help ?
OLDROD
PS. AS YOU CAN SEE I AN'T NO AUTOMATIC TRANNY MAN.
Old 06-23-2010, 07:14 PM
ericnova72's Avatar
More for Less Racer
Fully describe the symptoms of what it is doing.
Old 06-23-2010, 07:35 PM
As I said in the first post the thing will stall when put in gear or at stop lights,stop signs and such also it will get hot if I keep the rpm's up high Enif to keep it running and hold the brake. I have bumped it in neutral to drive it a little but any town driving is out and I need the front end lined up tow set and ect. It seems worse when hot but will run on down the road and shift right as long I don't have to stop.
THANKS OLDROD
Old 06-23-2010, 07:38 PM
ericnova72's Avatar
More for Less Racer
Sounds more like a timing or carb issue at this point.
Old 06-23-2010, 08:12 PM
I watched it on the dino carb,timing all good around 450hp roller 347 stroker it will go from a to b fine and even idle in gear in the shop most of the time it just does this stalling crap at red lights stop signs ect as I said before it will run like a bat out of hell BUT this stalling is the pits. It will run all the gas out in a straight line just don't idle.I have a friend with the same problem with a 302 w/C-4 and 2400 stall converter. I was wondering if the stall was to low like maby I needed a 2800-3200 .
OLDROD
Old 06-26-2010, 06:04 PM
OLDROD
Finally got the thing on a rack so I could see the new mufflers and pipes and the boy had done a bang up job except the pipes are to close to the transmission mission cooler and lines or at lest I THINK SO will this cause the kind of problem i am having? The cooler is the under car kind seen on a lot of street rods as there an't room for one in the radiator or at lest no one I talked to made one for the 37 WILDROD.Any one had this kind of problem with the cooler under the car? Oh it seems worse in reverse
thanks OLDROD
3200 stall convertor question ss396si Transmission - Rearend 2 10-24-2008 02:13 AM
Too many Rpms - Convertor slipping or stall speed too high? heyjude076 Transmission - Rearend 2 09-17-2008 01:32 PM
stall convertor selection john chaffin Transmission - Rearend 1 05-11-2005 11:09 PM
Do I need a stall convertor Magic396 Transmission - Rearend 1 08-28-2003 11:34 AM
identify stall convertor brad_irc Transmission - Rearend 1 08-26-2003 07:08 PM
