Stall convertors - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2002, 12:17 PM
jhulon's Avatar
New Member
Post Stall convertors
ok fellows i have a 1965 chevelle ss when i bought the can the man told me it had a 2400 stall in it but iam not sure about that. when i put it in drive it wants to jump forward not much but some. my question is how can i tell what convertor is in it. the stall is painted blue if this helps any. thanks for your help
Old 11-23-2002, 02:23 PM
Canzus's Avatar
a red wool sock on his dinger
Post
Heres how to check your stall...
Put your foot on the brake, really hard...
Put the car in gear, and run the rpm up,
the tires will start to spin, or the engine
will die at the converters stall speed...
Canzus
That blowed up real good...
Old 11-23-2002, 07:06 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
That is not how you know stall speed. Stall speed is dependant on alot of things. It will be different behind a different motor, and the stall speed is actually the speed the converter will allow the motor to rev to before it engauges. The torque of the motor and the weight of the car are the determining factors. When I went from a 350 to a 400 sbc I gained about 300 rpm on my 10 inch street fighter.
You find the stall speed with a foot brake. A little more accurate way is to start at a slow roll and punch it. Watch the tach and it should bounce to a set rpm and hang there for just a second. If the car has any power however, it will probably spin and you will not know the stall speed. At the track on slicks you could find the stall speed acuurately.
Chris
