stall engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2012, 01:58 PM
stall engine
i have a 350 chevy engine in my camaro,i have to idle it up to 1000 to 1500 rpm before putting gear,I don't know why i can't put it in gear at a lower rpm without stalling. I have a B&M 2000 stall converter someone tell me what is my problem. thanks jumpalene
Old 11-27-2012, 03:10 PM
RWENUTS's Avatar
Not enough initial timing!
What's it set at now?
Old 11-27-2012, 03:35 PM
Bye Jerks
You didnt tell us how big your cam is.
You might need more initial timing, or a looser converter. 2000 stall isn't much over stock.
Big cams don't make much vacuum at idle. When you advance the timing at idle, it will increase the RPM's slightly. Watch to make sure you don't have too much when it goes to full advance.
You might have too much curve. I hope you have a timing advance light with a dial on it.
On my distributor, I just unplugged my vacuum advance. I don't use it.
Initial is 18deg and full advance is 36 just on the weights.
My cam isn't that big, but it's pretty big for a hydraulic flat tappet.
Old 11-28-2012, 07:45 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Carb and timing.
Old 11-28-2012, 10:49 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Vacuum leak.
A/C shuts causes engine to stall 1969chevyss Engine 4 08-22-2011 11:57 AM
Engine stall Hellalive89 Engine 7 04-30-2011 11:18 AM
Engine Stall aholcombe Engine 4 04-07-2011 04:32 PM
engine stall adrock430 Engine 1 06-13-2005 07:54 PM
CAMARO engine STALL Ramzes1 Engine 8 01-27-2004 04:04 PM
