stall & shift kit installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2006, 11:30 PM
Jacks 1977 Corvette
I have a 77 Corvette with a 383 stroker running NOS with a TH350 3spd auto w/ 3:73 gears and I would like to install an 2,400 stall & shift kit.
Anybody here done that and maybe have some instructions on doing it? Is this something I can do in my garage or should I farm it out?
Old 01-20-2006, 05:14 PM
You can do both in your garage with a buddies help. Dont let someone else do it. You will be proud of your self when you get it installed and hear that thing bark 2nd.
Well you will have to pull the tranny out (or at least back) from the engine to install the converter. You may as well go ahead and pull the tranny out from under the car, this will make the shift kit installation go a little eaiser. However you can put the shift kit in with the tranny still bolted to the engine.
Converter change: Remove dust cover. Remove 3 converter bolts. Remove drive shaft. Remove the 6 bolts holding the tranny to the engine. put a jack under the pan and take the pressure off the tranny with it. remove cooler lines, shifter linkage, and your kick down cable. then remove your crossmember that supports the rear of the transmission. slid tranny back away from engine so you can get to the converter. Turn an pull on converter and it will pull right out. When you install new one put 1 or 2 qts of fluid in it. (Lube the nose of it with tranny fluid) Then twist and slide it on. BE SURE IT IS ALL THE WAY IN! It should go about to "clicks" before it is in place. Then install in reverse order.
Shift kit: IF you are fairly mechanically inclined the shift kit will be no trouble. The instruction (detailed) will come with the kit you buy. IT is fairly simple. Just involves removing pan, valve body and seperator plate. Some kits have stiffer springs for the valves in the valve body. All will have new seperator plate and gaskets. Probably about a 3 hr job if you have never done it.
Any more questions and I will be glad to try and help
Jeremy
Old 01-20-2006, 10:02 PM
Jacks 1977 Corvette
Thanks for the tips Jeremy.
Aren't you suppose to support the engine when you loosen the tranny?
Old 01-22-2006, 08:05 PM
Yep your're right. I knew I left out something. Just put a floor jack with a board on top of it under the oil pan.
Jeremy
Old 01-23-2006, 06:22 AM
mike 96 ws6's Avatar
old dog learning new tricks
If you install the shift kit while it's in the car, when you get ready to re-install the valve body, use some Vaseline Petroleum Jelly to hold the check balls in place. {actually I always only re-installed 1 check ball on the TH350} Just don't use grease to hold the ball {s} in place.
b&m Shift improver kit need help th350 onebad98z Transmission - Rearend 3 04-20-2005 08:16 PM
shift kit rebuild kit help roy383ci Transmission - Rearend 1 03-26-2005 08:17 AM
what does a shift kit do? batman09 Transmission - Rearend 11 02-18-2005 08:43 PM
trans shift kit chev kev Transmission - Rearend 4 02-08-2005 08:32 PM
SHift kit smokin1980chevy Transmission - Rearend 5 09-04-2003 12:03 AM
