stall size - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2006, 04:26 PM
stall size
i have a cam with 288 294 dur and 501 501 lift what size of a sall should i go with
Old 12-12-2006, 04:55 PM
How big is your car? If you're going to use a stall you should have enough room to open the doors without scratching the paint.
Old 12-15-2006, 08:50 PM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
Thats kind of a loaded ? weight of car , gears etc and how your going to use it what kind of car is it and what engine and tranny
Old 01-10-2007, 09:37 PM
techinspector1's Avatar
Wiki Edits: 326
Without knowing the specifics, I'll tender a SWAG of 3,000 stall and 10 to 11.5 compression ratio.
what would be the best stall converter for me? tiresmoke55 Transmission - Rearend 3 08-30-2006 03:42 AM
4.56 or 3,500 stall juiced66malibu General Rodding Tech 3 08-19-2006 11:41 AM
ikm thinking about using a higher stall converter spinn Hotrodding Basics 2 06-01-2006 12:15 AM
Bore size question 53LEDSLED Engine 5 05-12-2005 06:55 PM
stall speed? Thacolbster Transmission - Rearend 10 09-09-2003 02:48 AM
