stall speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2008, 08:16 AM
stall speed
A friend tells me that installing a th350 torque converter in a th400 will raise the stall speed. Assuming the stall speed is normally about 1600-1650 with the th400 converter, what will it be with the th350 converter?
Old 02-26-2008, 07:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
it is the converter diameter. The factory t-350 converter was slightly smaller in diameter than the t-400.
There were also different factory rated stall RPM converters for the t-350 & t-400 trans
stall speed speed_demon666 Engine 2 11-16-2007 07:21 AM
Torque Converter Stall Speed leejoy Transmission - Rearend 2 09-17-2006 10:43 AM
Stock C6 stall speed? Steve-0321 Transmission - Rearend 0 01-30-2004 11:20 AM
Stall Speed trees Transmission - Rearend 6 04-13-2003 06:59 PM
do I need to install a stall speed? the ernster Transmission - Rearend 2 04-13-2003 08:59 AM
