Which stall speed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2009, 03:32 AM
Which stall speed
Just picked up a trans am with a 388 motor trans is dead, 700r4, building a manual shift 350 to ogo in it, not sure which stall speed would be best. I estimate the car to be around 3000lbs now. cam is a 244/252 536. rear is a 3:73 posi. tire will be 29 inches. car will be a 1/4 mile strip car. Thanks for any suggestions.
Old 04-05-2009, 01:52 PM
fast68's Avatar
likes chevy trucks & boobies
i have an 82 t/a also
i run a bone stock 4 bbl 1983 caprice 305 and a th350 i stuck in it from a 77 van
i run a 2400 stall converter
and it runs ****in strong!!!
like it gets up and FLIES, at low speed even, and thats with the crappy open drum 2.73 axle...
so hmmm..
maybe that will give you an idea.
possibly.
hahaa
Old 04-05-2009, 08:21 PM
ericnova72's Avatar
More for Less Racer
With a tire that big and that cam, for drag use, 4000 would be my minimum and something 4500-5000 would be the best choice. Trying to compare your set-up to Fast68's is a total waste of time.
Old 04-06-2009, 06:11 AM
Thanks, for the reply, That gives me a direction to go on. I was thinking that 4000 or better would be what I needed, but needed some more insight.
Old 04-06-2009, 11:15 AM
prostreet6t9's Avatar
Differential/Driveline
IMO a 2400 would not be enough. You can always call the converter tech's and see what they say and make your choice from there.
stall speed speed_demon666 Engine 2 11-16-2007 07:21 AM
Torque Converter Stall Speed leejoy Transmission - Rearend 2 09-17-2006 10:43 AM
Stock C6 stall speed? Steve-0321 Transmission - Rearend 0 01-30-2004 11:20 AM
Stall Speed trees Transmission - Rearend 6 04-13-2003 06:59 PM
do I need to install a stall speed? the ernster Transmission - Rearend 2 04-13-2003 08:59 AM
