stall speed help - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-08-2010, 06:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I can also vouch for Coan and Continental Torque Converters (CTC).
  #17 (permalink)
Old 03-08-2010, 08:28 AM
bentwings's Avatar
bentwings
I've got a 3000 in my Willys at 2700 lbs and it is just perfect for the street with 3.50 gears and 31 in tires. Sorta wish I had 3.73 but with the blower you just step on it a little hard if you want to go quicker.
I think I'd take the Vega over to the Cat scale for an accurate weight. It only costs 8 bucks or so and you can get front and rear weights at the same time.
stall speed speed_demon666 Engine 2 11-16-2007 07:21 AM
Torque Converter Stall Speed leejoy Transmission - Rearend 2 09-17-2006 10:43 AM
Stock C6 stall speed? Steve-0321 Transmission - Rearend 0 01-30-2004 11:20 AM
Stall Speed trees Transmission - Rearend 6 04-13-2003 06:59 PM
do I need to install a stall speed? the ernster Transmission - Rearend 2 04-13-2003 08:59 AM
