stall speed help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2010, 04:25 PM
stall speed help
ok here we go.
71 vega.2500lbs.373gears.th350trans,26-27inch tires
.383ci..540lift.234durration,10.5:1comp
750cfm vac sec
performer rpm .did i miss anything?
any recomendations on stall speed ? will be using car for street and ocasional strip
Old 03-01-2010, 06:22 PM
hey john going over 3500 will make it agervating to drive onthe street been there done that
Old 03-01-2010, 08:34 PM
I would run at the least a 2800. Had a prostreet S-10 with a wicked 355 and ran a 3200. Wasn't too bad. Caught hell when it rained though, LOL. Poor bf goodrich tires.
Old 03-02-2010, 09:07 PM
S10xGN's Avatar
Gotta love a turbo!
Depends on what you're willing to spend. A good 3500+ converter that will work on the street can be had, but they are expensive. I have two vehicles with 3500 stall 9.5" diameter single-disc L/U Precision Vigilantes. Both are street driven and very well mannered. These converters in single-disc L/U are about $750. In contrast, I've tried running a stock diameter 12" restalled to 3000 and it was a ($300) joke.
Russ
Old 03-07-2010, 08:41 AM
the tec guys at tci told me to use the streetfighter 3000 ,said it would flash at 2800-3000 rpm
and the tec guy at heughes told me to use there 3000big block and it stall
2400-2500 rpm
now im confussed?
Old 03-07-2010, 09:13 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Originally Posted by johnbelanger
ok here we go.
71 vega.2500lbs......
Have you actually weighed this car? Unless it's a tube chassis with a lot of fiberglass and aluminum, I'd bet it's probably closer to 2900,
Not that it makes a lot of difference, but I've owned some Vegas myself, small block and big block, and none were that light,
Old 03-07-2010, 10:16 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
2400-2500 rpm
now im confussed?
You have two different situations posted there.
Flash stall RPM and stall RPM are different , different method of operation of a converter.
A converter may stall against the brakes at 2500, yet it may flash to 2800 RPM when properly operated.
A flash stall is obtained by holding the car with the brakes , bring the throttle up to a RPM where the camshaft lope is mostly cleared. Then hammer the throttle as you release the brakes ...for a short moment the converter will flash to a higher RPM than it would by simply hold the brakes and stab the throttle.
If the tires spin when flash stall is attempted , then you have a false RPM indicated
Old 03-07-2010, 11:22 AM
the wieght was just a guess ,out off these two companys who has the better reputation?
Old 03-07-2010, 11:29 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I've worked for Hughes for over 11 years, so my opinion is a bit biased
Old 03-07-2010, 01:08 PM
ok here we go.
750cfm vac sec
3000 to 3500 wouldent go more than that
Old 03-07-2010, 07:54 PM
ericnova72's Avatar
More for Less Racer
If the two you are referring to are TCI and B&M then I would say "other". Their street line of converters are closer to the joke catagory than the quality side. This is one of the bad areas to get cheap, good rule of thumb given to me for converters in this range(2800-4500 stall, 9-9.5-10" diameter) is that if you are not spending $450 you are getting a compromise part, just the necessary parts to assemble the converter alone cost $300+. Anything cheap has corners cut in the converters construction.
I'd say 3000-3200 stall in your case, 3600-3800 if you really want to "tear it up" at the track..
Old 03-07-2010, 10:06 PM
im willing to spend $400-$500 maybe more on the right one what other companies do you
recomend?
Old 03-07-2010, 11:40 PM
ericnova72's Avatar
More for Less Racer
Dynamic, Hughes, PTC, ATI, Coan
Old 03-08-2010, 05:08 AM
Rickracer's Avatar
I can add JW Performance to that list, I know you've heard of them, they make the Ultra Bell, and they build some first class converters. www.racewithjw.com ,
Old 03-08-2010, 06:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I can also vouch for Coan and Continental Torque Converters (CTC).
stall speed speed_demon666 Engine 2 11-16-2007 07:21 AM
Torque Converter Stall Speed leejoy Transmission - Rearend 2 09-17-2006 10:43 AM
Stock C6 stall speed? Steve-0321 Transmission - Rearend 0 01-30-2004 11:20 AM
Stall Speed trees Transmission - Rearend 6 04-13-2003 06:59 PM
do I need to install a stall speed? the ernster Transmission - Rearend 2 04-13-2003 08:59 AM
