Stall speed question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2005, 03:10 PM
81T/A's Avatar
it will hook around 2200 that is your stall
i was just wondering is that how you find out your stall?
Old 08-17-2005, 04:57 PM
If you can find the k factor of your converter (i.e. from the manufacturer),
multiply that times the square root of your engine's torque
at a given rpm.
For instance, a Ford 4R70W & AOD/E 12" converter has a k
factor of 165. My 351 has a torque of 300 lb-ft at 2500.
The square root of 300 = 17.3 x 165 = ~2850 stall rpm.
Being 2850 is higher than 2500, the torque is likely to be
a little greater at 2850, so the stall would be higher than
2850 by a little.
