with just a mild 350 a stock converter im sure would do the job. my motor is making around 400hp and i have a stock converter and it works fine. besides, what size cam do you have???im sure if its somewhere around a 290duration than you might wanna get about a 2000 stall converter. hopefully im right on this info......later
see other post, i have a 406 in a S-10, 373 gear, lots of goodies in the motor, but the truck has to be usable every day, because of the cam (230-505)i went to the 2400-2800 convertor with lockup, with a milder cam i would have gone for about 2000-2200
A 2500ish 11 inch converter will give the motor a little slack, but not be too loose to drive every day.
Chris |
I'm not much of a cam #'s kinda guy. Its lumpy enough that at idle I have nearly no brakes. Until my dad added a Vacuum booster deal, I don't know how they work, but I got brakes now. I was leaning towards 2200-2400 stall. Thanks for the help.
BOBCRMAN, how does that 406 do for heat. Mine originally had a Real nice 400, but the temp guage would spike after sitting for more than 10 minutes at an idle. I've got two 12" (I think) scirroco fans, and a 4 core high efficiency rad (not alluminum), I had to swap that motor out cause it just got to damn hot. I was thinking if I removed the inner fenders, or put a hood scoop on the truck the air would have somewhere to go. What do you do? bonuts |
